double groove water pump pulley
Interested in double groove water pump pulley for my 455 to accomodate power steering addition. Would rather support someone here than a no name outfit. let me know what you have and for how much?
Would you post the two letter code on the crank pully you plan to use with it? I've had lousy luck trying to change individual pullys so I usually go with a full set to make sure the belts line up. John
Ugh. Thought it was a straight swap as most aftermarket appear to accommodate both 350 and 455 without specifying anything else. I don't have the radiator, etc. Removed yet so will have to get back to you. Thanks though.
EightyEightCut
January 18th, 2013 09:23 AM
