double groove water pump pulley
Old Feb 11, 2012 | 07:35 PM
4speedBench's Avatar
Interested in double groove water pump pulley for my 455 to accomodate power steering addition. Would rather support someone here than a no name outfit. let me know what you have and for how much?
Old Feb 11, 2012 | 07:50 PM
2blu442's Avatar
Would you post the two letter code on the crank pully you plan to use with it? I've had lousy luck trying to change individual pullys so I usually go with a full set to make sure the belts line up. John
Old Feb 11, 2012 | 11:07 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Yes. We will need to know what letter your crank pulley is, what letter your steering pulley is, and how long your water pump snout is. 5.1" 5.6" or 6.1"
Old Feb 12, 2012 | 04:45 PM
Ugh. Thought it was a straight swap as most aftermarket appear to accommodate both 350 and 455 without specifying anything else. I don't have the radiator, etc. Removed yet so will have to get back to you. Thanks though.
Hairy Olds
Jun 25, 2013 10:28 AM
EightyEightCut
Jan 18, 2013 09:23 AM
defiant1
May 7, 2011 08:21 PM
Oldsmaniac
Nov 11, 2010 04:57 PM
longboardguy
Jun 25, 2009 04:48 PM
