disc brakes for 69
disc brakes for 69
I'm looking for a factory disc brake set up for a 1969 cutlass S. I would prefer something within 75 miles of Cleveland, unless its really cheap, then of course I'll drive farther ?
if nobody closer has what you want i have some options for you. i have a set of spindles, backing plates, and caliper brackets i would sell for $125 plus shipping. you would have to come up with the rotors, calipers, master cylinder and metering valve.
i also have a complete setup from a 70 cutlass with the valve by the master cylinder. the backing plates are not that great on this set and i have no idea what the condition is of the calipers and don't know if the rotors need turned or even if there is enough to them to turn them. i do know they worked when i took them off the car but never drove it more than 100 foot. i would want $250 for this set. it would be much higher for shipping. if interested i can get you pictures but may be after thanksgiving.
i have brand new 1 piece rotors never used.. not turned but new .. 125 for the pair plus th ride
brake setup
i have a complete set up all fresh.
parts as listed
new front calipers and brakes
new factory type rotors
new master cyl
fresh bearings just installed
original backing plates
valve
spindles
all parts needed to complete install
there is maybe 10 miles on all new parts
350.00 for the set up
if interested call john @ 847-508-5090
this is the best way to get me
parts as listed
new master cyl
valve
spindles
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
