Convertible Rear Door Panel Uppers 1972
Old January 9th, 2023 | 10:19 AM
Bad68442's Avatar
Hi all,
Ordered new from door panels from Legendary awhile back for my 1972 Cutlii convertible. At the time I thought my backs were OK. Now that I have the new fronts .. I realize just how bad the back look .
Legendary wants me to send my uppers to them and they will assemble ... but looking at my drivers side rear door panel, the upper piece has a few cracks and small pieces missing ... so looking for a replacement.
Please let me know if you have one for sale.
Jim
Old January 9th, 2023 | 12:27 PM
allyolds68's Avatar
Originally Posted by Bad68442
Hi all,
Jim
Legendary used to offer a repro that used plastic where the metal is for their "assembled" panels but when you sent them your originals they would re-use the metal and still charge you for "assembled". That's what I did but since I live 20 minutes away I just dropped my old ones off
Old January 9th, 2023 | 03:10 PM
Bad68442's Avatar
HI Mike,
Thanks for the info, I will call them again tomorrow. To get the assembled pieces I also have to send them my originals, they did not say anything about having a replacement upper.
I mentioned mine were cracked ... and they said could repair ... @ 85/hr.
My 72 uppers are a white plastic from the factory, not metal. Hard to believe that no one sells the upper piece..metal or plastic.
Jim
Old January 9th, 2023 | 03:26 PM
PatL's Avatar
HI Mike,
Jim
JIm,
I am not sure if the rear convertible panels ever came complete as reproductions. The fronts used to have the steel piece at the top later replaced by plastic. I did a 1971 set in PUI on a 1971 convertible and had to assemble the rears myself around 23 years ago (you basically removed the top plastic from the original and glued to the reproduction. I just did the same thing again on the rear panels around 4 years ago, when I replaced all that with Legendary. I am not aware of that part of the convertible rear panel being reproduced
I assume that top plastic is broken in yours. You may want to try repairing it with something like Bondo.
Old January 9th, 2023 | 07:25 PM
tkcutlass's Avatar
is this what you're looking for? (Rear panel)
I saved a few I may have a metal top.
Old January 10th, 2023 | 10:21 AM
Bad68442's Avatar
Hi Tim,
Thanks for the response! I need the rear door panel, the part with the hole in it for the rear window crank. I do not need the rear arm well pieces or front door panel. Do you have any extras you can sell?
Old January 10th, 2023 | 10:44 AM
tkcutlass's Avatar
I should have something, do you need both sides?
​​​​​​​I should be able to take a look later today.
Old January 10th, 2023 | 02:04 PM
Bad68442's Avatar
Hi Tim,
The drivers side is pretty busted up ... so definitely need that. Passengers has a few small pieces missing along the top ... but if yours is better I would probably take both.
Jim
Old January 10th, 2023 | 03:14 PM
tkcutlass's Avatar
FWIW Looks like PUI has assembled versions.
Old January 10th, 2023 | 04:01 PM
Bad68442's Avatar
Hi Tim,
I know ... I did call them as well ... but I have heard that the PUI backs might not match my Legendary fronts ... so I was trying not to go that way
Jim
Old January 10th, 2023 | 04:50 PM
tkcutlass's Avatar
Looks like I have a 70 set - a 72 set and a passenger-side single.
72 is close to driver's quality.
70's are beaten up but good tops.
Old February 6th, 2023 | 07:08 AM
ROCKETMAN269V's Avatar
Did you ever get the panels that you need? I just brought a trailer load of parts from my warehouse and have some decent black rears. Please let me know. Thanks, Bob.
Drsantos
October 4th, 2018 10:26 AM
Z.cutlass
November 8th, 2017 05:52 AM
Brett
July 1st, 2013 09:05 AM
oldgold
July 2nd, 2012 08:10 AM
dsolomon
January 1st, 2012 06:06 PM
Quick Reply: Convertible Rear Door Panel Uppers 1972
