clutch and brake pedal assembly
I need a clutch and brake pedal assembly for a 63 olds 88 so I can change out from an auto Trans to a manual. If you have one or know where I can get this please let me know
You don't ask for much.
Given that about 2% of 1961-64 production had a stick, you're looking for some pretty rare stuff. Then you have to find a stick bellhousing compatible with the 394.
If you're not concerned about original appearance, use aftermarket swinging pedals and a hydraulic clutch assembly. I don't know what to tell you on the bellhousing.
GOOD Luck.. Hard enought to find for a 64-72 442 Let alone a 63. I would use generic parts and make it work as rocketraider said, a hydraulic clutch. at least you can make everything custom to ur liking
if it where me..id look at the 62-3 pontiac pedals..they actually have so much demand they repopped them...try to get a factory parts manual pic and look at the pontiac stuff...see if you can make it work before ya buy..
one thing..theres 2 pedals...well...just one, but they call one set super duty, but its just a heavy duty spring..
pontiacs have an issue...power brake and manual brake are different...the pivot is in diff spots power and manual too...so you have to figure that all out..
i wouldnt be worried...id look around a little see what GM stuff you can use..and run with it...they must have made a million stick shift impalas belairs and biscaynes...
oldspackrat
February 5th, 2013 06:35 AM
