Camshaft
Old Feb 24, 2026 | 05:14 AM
Oldzskool's Avatar
Camshaft
Looking for a stick that needs no stall and is already broken in with the lifters.will be going in a 455. Want to start driving my car a lot more. Lift in the .460 to .480 range. LSA110 to 112. No rollers. Prefer a flat tapper hydraulic. Looking for just a good daily driver camshaft. thanx for reading.
Old Feb 24, 2026 | 11:33 AM
ROCKETMAN269V's Avatar
Originally Posted by Oldzskool
............. Duration 110 to 112...............
That isn't going to make any power, if it will even run.
Old Feb 24, 2026 | 12:45 PM
Oldzskool's Avatar
I meant LSA. Use some common sense.
Old Feb 24, 2026 | 05:58 PM
My understanding is lifters can be re-used only in the block and bores where they were initially broken in. For a used cam in a different block, new lifters are needed. And EVERY torque converter has a stall speed rating, so you need to determine what stall the converter you are using has in order to match the cam to its stall speed.
No stall = manual transmission.
Old Feb 25, 2026 | 04:35 AM
heatmup's Avatar
Call Ken at Oregon Camshaft and tell him to send you an 859 cam.
Old Feb 26, 2026 | 09:09 AM
Not everyone on this forum is well versed in camshaft terminology. Just trying to not confuse anyone. No harm intended.
Biglinny
Feb 16, 2016 07:45 PM
rico.455
Sep 9, 2013 05:31 AM
RAMBOW
Jan 12, 2012 08:25 PM
TripDeuces
Jun 16, 2010 11:09 AM
procharged70cutlass
Dec 21, 2009 08:03 PM
