A/C driver side duct
Old Mar 14, 2016 | 05:54 AM
Russ46350's Avatar
I am looking for the drivers side plastic duct tube for my 69 Cutlass.
Old Mar 14, 2016 | 09:24 AM
lunaboy's Avatar
The Rocket Astronomer
found it but the mounting tang is broken. 20.00 and its yours to modify
Old Mar 14, 2016 | 02:21 PM
jensenracing77's Avatar
I have a really nice one but it would be more money. I will post pictures of it. I would want $30 and shipping or pick up in Brazil Indiana
EDIT... Sorry, This is a 70-72 that I have.
Old Mar 14, 2016 | 02:31 PM
lunaboy's Avatar
A closer look at mine , suspect it may be 70-72 non a/c ?
Old Mar 14, 2016 | 02:45 PM
70Post's Avatar
I have the duct shown the pics below...pulled from a '69 Cutlass. Overall good condition but has one area where the plastic had a small, somewhat-circular crack (3rd pic) and I glued that area.
Also, a small stress crack near the mounting hole on the tab which I suspect is common from use(4th pic).....I would add some cement/crazy glue to this small stress crack and use a mount screw with a flat washer under it (if it's a #8 screw I'll include the screw with the captive flat washer).
$45 + shipping....Check or MO....no paypal.
If you are looking for "super slick" I can also clean it well, blend/fill/hide the small "circular" crack and the other stress crack and shoot it with a good plastic/vinyl paint but that will add some extra $ to the cost. Easy enough to do yourself.
Old Mar 14, 2016 | 06:19 PM
Russ46350's Avatar
Driver side duct
Thanks for the quick replies. I got an initial pm from someone and we worked it out. Thanks everyone.
Old Mar 15, 2016 | 07:28 AM
Russ46350's Avatar
On going saga
I have learned a valuable lesson in the fact that you have to be very specific on the parts you buy. I purchased the a/c manifold a few weeks ago and it turns out it's for a 70 and will not work on my 69. So I am now looking for the piece in the picture.
Old Mar 15, 2016 | 12:36 PM
ROCKETMAN269V's Avatar
'69 a/c manifold
The assembly manual shows a 1st type (399408?) & a 2nd type (404143), which was later cancelled. You may want to look for a part# on yours. It will save further confusion.
Old Mar 15, 2016 | 12:56 PM
Russ46350's Avatar
Good advice
Old Mar 15, 2016 | 02:15 PM
airvegas's Avatar
duct
I have this model duct as well as the other too, 25 bucks plus whatever shipping cost is to you. I wonder if you are the same person that called me the other day on one?
I suspect it will fit insode the large USPS flat rate box as long as I pack it well and cushion it, I thionk it should make the ride fine.
Pictures are attached to this. PM me back if you want it and I will get it out first thing in the AM. I take PayPal for payment
Old Mar 15, 2016 | 03:06 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Im looking for a mint NOS or equivalent 68 driver side duct as well. Has to be mint no cracks.
CQR
Jun 2, 2014 03:30 PM
Bernhard
Apr 27, 2013 10:54 PM
olds70supreme
Mar 27, 2013 07:51 PM
Pacecar
Oct 21, 2012 06:41 PM
dschallock
Apr 30, 2011 12:08 PM
