A/C brackers for my 67
Old Sep 18, 2016 | 07:08 PM
steverw's Avatar
Hey guys, my car is a factory air car, but when i got it, it was missing the compressor and a couple of brackets. I have the to big cast brackets and the long brace for the front to water pump stud. Im missing, i think, a short flat brace for the rear of the pump, and a squarish bracket that bolts on to the front side that has the adjustment slot. Also my car was an A.I.R. car, i removed all that junk, still have it if anyone needs it. But the front cast bracket has an extra boss to bolt the A.I.R pump to, so i would prefer to have one without that provision.
Old Sep 18, 2016 | 07:12 PM
steverw's Avatar
You can see the hole in the front cast bracket that was for the A.I.R pump. The cast bracket that goes over the valve cover is ok. I have another 67 that has all the brackets im seeking but i hate to rob them as its a complete car. And its for sale...67 Saffron auto.
Old Sep 19, 2016 | 11:17 AM
steverw's Avatar
bump
Old Sep 19, 2016 | 04:18 PM
tru-blue 442's Avatar
Old School Olds
Steve, can you take a pic from the Saffron car of the pieces needed?
I may have something you can use, but I'm not sure of what it is you need.
Old Sep 19, 2016 | 07:38 PM
steverw's Avatar
Ok thanks ill get the pics tomorrow. Just realized i should have put this in parts wanted classified. Sorry
Steve
Old Sep 20, 2016 | 08:41 PM
steverw's Avatar
heres pics, its the front cast bracket goes from head to comp. also the compressor im showing a bracket that kind of wraps around the front of the compressor, it has the arced sliding adjuster slot, and also a short strap at the rear.
Old Sep 20, 2016 | 08:45 PM
steverw's Avatar
The bracket in the middle pic goes down the inboard side and under the comp. I has a long slot for adjusting the belt tension.
Heres an over all pic
Old Sep 21, 2016 | 05:41 AM
Old School Olds
Here is what I found Steve. From left to right, the lower cast brackets.
Part #'s, 391188 next 398682 and last 398684. I didn't have any luck on the others
but you may try Larry or John for the rest.
Old Sep 21, 2016 | 11:51 AM
lunaboy's Avatar
The Rocket Astronomer
a/c brackets 66 67
this is what i have from a 66 . complete set.
pm if interested.
