A/C brackers for my 67
Hey guys, my car is a factory air car, but when i got it, it was missing the compressor and a couple of brackets. I have the to big cast brackets and the long brace for the front to water pump stud. Im missing, i think, a short flat brace for the rear of the pump, and a squarish bracket that bolts on to the front side that has the adjustment slot. Also my car was an A.I.R. car, i removed all that junk, still have it if anyone needs it. But the front cast bracket has an extra boss to bolt the A.I.R pump to, so i would prefer to have one without that provision.
You can see the hole in the front cast bracket that was for the A.I.R pump. The cast bracket that goes over the valve cover is ok. I have another 67 that has all the brackets im seeking but i hate to rob them as its a complete car. And its for sale...67 Saffron auto.
heres pics, its the front cast bracket goes from head to comp. also the compressor im showing a bracket that kind of wraps around the front of the compressor, it has the arced sliding adjuster slot, and also a short strap at the rear.
Here is what I found Steve. From left to right, the lower cast brackets.
Part #'s, 391188 next 398682 and last 398684. I didn't have any luck on the others
but you may try Larry or John for the rest.
