A-Body Disc Brake Steering Arms
Old Nov 25, 2019 | 03:20 PM
yeahbuddy's Avatar
Need a set of A-Body Disc Brake Steering Arms with 1/2 holes
Old Nov 25, 2019 | 03:29 PM
442crzy's Avatar
PM sent
Old Dec 6, 2019 | 05:10 AM
rocketscientis's Avatar
No diffrence from drum to disc steering arms ???
General consensus at another site seems to b that disc & drum breaks use same arms ....hav not investigated th issue ....have parts to compare but no time atm.....if true , hav many of them....
Old Dec 6, 2019 | 07:43 AM
They are. The differences are early and late. The early (1964-65-ish) arms use smaller diameter bolts that hold the arms to the spindles.
Old Dec 6, 2019 | 11:16 AM
Same steering arms diffrent size holes
Good to know ...one would assume larger holes in th disc brake units .can i drill out yours or hav you none at all...?
if still in need i have th drum ones from 65-72 & drill press & 30 years as machinist so little hole enlargement no problem
Old Dec 6, 2019 | 11:19 AM
Within a given year, the "disc brake" and "drum brake" arms are exactly the same part number. Yes, you can simply drill out the early ones from 7/16 to 1/2.
Old Dec 6, 2019 | 11:31 AM
Joe P knows
Dagnabit ..Joe....you' d save me lotta time takin lead bein in front ya know....thanks just th same
Tjohn8573
Brakes/Hydraulic Systems
Aug 28, 2019 11:34 PM
oldsfamily
Sep 1, 2014 01:23 PM
Murco
Mar 7, 2013 11:50 AM
66-3X2 442
Mar 29, 2012 08:50 AM
olds70supreme
Aug 31, 2009 01:31 PM
