AC and defroster ducts 68-69 442
Old Feb 20, 2011 | 05:08 PM
Beob's Avatar
Im looking for the AC ducts on passenger side only and defroster duct. The pics show what I have. Other years might also fit.
Thanks, Rob
Old Feb 21, 2011 | 04:27 PM
69442C's Avatar
Rob, I think I have these parts. Just to clarify: you need the passenger side plastic defroster duct that goes on the underside of the dash and the hose that connects your manifold to that duct? Correct? Do you need the center plastic duct that connects the top of the manifold you have to the center dash outlet?
Brian
Old Feb 21, 2011 | 04:32 PM
69442C's Avatar
Oppps, let me try that again. You need the flexible hose that goes from the manifold over to the passenger side dash outlet and then the duct work that connects the heater box to the defroster outlets. Correct? And then same question about if you need the center plastic piece that connects the top of your manifold to the center dash outlet. Let me know.
Brian
Old Feb 21, 2011 | 06:07 PM
Beob's Avatar
Brian
Hi Brian, I do need the flexible hose that goes from the manifold over to the passenger side dash outlet and the duct work that connects the heater box to the defroster outlets. I have everything else. If you have these too that would be great!
Thanks, Rob
Old Feb 22, 2011 | 08:30 AM
69442C's Avatar
Let me see what I have and I will let you know.
Old Feb 22, 2011 | 05:12 PM
69442C's Avatar
Rob, I do have the parts and I have posted photos. Note that the small round hoses that go to the defroster vents are not good but I think you can buy them new at the auto parts store. The rectangular hose I have is good. Also note that the small plenum for the defrost has a small piece broken off for the mounting bolt. A washer over the bolt should solve that problem.
I have also included a photo of the main vent manifold as the one you show is not correct for the 69 Cutlass cars. The difference is the outlet that runs over to the passenger side vent is square on the 69's whereas the one you have is round. The hose for that side and the plastic end on the hose needs to connect to a square fitting rather than a round one. I'll sell the one I have if you need it. Just note that the one mounting tab on the lower right is broken off. I'm sure you can fab something to make that work such as to epoxy a small tab over that area to replicate what was there.
The price for everything I show is $45. If you don't want the plenum with the square outlet, deduct $20. Shipping will be extra and I'll just need to know what pieces you want so I can price the shipping.
Brian
Old Feb 23, 2011 | 09:32 AM
Beob's Avatar
Brian, I found the correct main manifold in my shed so I dont need that. I will take the other 2 pieces you show in first pic. Any broken pieces is ok. Also do you have any black rear seat belts you might want to sell.
Thanks very much, Rob
Old Feb 23, 2011 | 10:08 AM
69442C's Avatar
Rob,
I'll get you a shipping price and your total this evening and will PM it to you. I do believe I have extra rear belts that are black and will check on those tonight as well.
Brian
Old Feb 23, 2011 | 04:16 PM
69442C's Avatar
Hey Rob, just sent you a PM. I do have a set of black rear belts that need to be cleaned up and here are the pictires. More details are covered in the PM.
Thanks,
Brian
Old Feb 25, 2011 | 04:41 PM
Lalo442's Avatar
Hey Brian do you have the drivers side plastic piece for a 69 for the drivers duct ???
Old Feb 25, 2011 | 04:57 PM
69442C's Avatar
Which piece do you mean? Your previous photo showed you had everything that went from the manifold through an oval piece of plastic duct about 12" long, to the square hose. The only other piece is a plastic piece that is connected to the vent that would accept the square hose. Is that the piece you mean? If so, I do have it. Let me know.
Old Mar 5, 2011 | 06:34 PM
67442nut's Avatar
I have these duct pieces in the "For Sale" section if anyone can use any of them:
https://classicoldsmobile.com/forums...ash-ducts.html
https://classicoldsmobile.com/forums...-ductwork.html
WTony
Aug 21, 2014 07:04 PM
mannyf85
Jun 23, 2014 07:26 AM
rcktdoc
Jun 9, 2014 04:34 AM
442mark
Jul 30, 2013 04:59 PM
1968_Post
Apr 24, 2013 12:23 PM
