77 Cutlass Supreme need engine and transmission
Old Oct 7, 2019 | 08:28 AM
Qbass1129's Avatar
Gm, im in search of a working olds engine and trans. I havent been getting any luck with finding anything thats in my price range. If anyone can point me in the rite direction, ill appreciate it. Thanks
Old Oct 7, 2019 | 02:31 PM
deadeyejedi's Avatar
Not sure what your price range or engine size requirements are but i had a rebuilt 307 olds and rebuilt trans attached both worked beautifully ready to drop in and go ,had a brand new quadra jet on it with all accessories.finally just sold it for 400.Expect to pay considerably more for this same combo in a larger cubic inch.There are deals out there if your willing to hold out for them.check the parts for sale section here ,as well as craigslist and facebook marketplace.
Old Oct 7, 2019 | 03:37 PM
bigdooly's Avatar
Where are you located? You willing to travel? Do you have means to transport an engine? What is your price range?
Under parts for sale is a listing Pea Soup IV parting out a 1975 delta 88 4dr. It has a 350 4bbl. There is 25,600 miles on it. It was one family owned, based on the lack wear in interior and on gas / brake pedals and what I was told by the sellers I believe the mileage is true.
I have not run it as of yet. I have pulled the plugs, oiled the cylinders, spun it, and compression tested it. 150-160 all cylinders. I have some new fuel line, I plan on running it off a can because whats in the tank who knows. I just haven't had the time to fire it up. The Transmission you likely would not be interested in it is the th375.
which is basically a light duty 400.
The car is in north east Pa. {Poconos}. I let one go a couple years ago for $700, a 350 from a 74 delta 88, that 21,400 miles on it. So $700 is my price. I would sell it complete with the exception of ac pump and brackets.
Jim
Old Oct 7, 2019 | 07:00 PM
Qbass1129's Avatar
Thanks for the response, im in Nj. Im probably 2 hours from Tannersville. I have a pick up so transportation isnt a problem
Old Oct 7, 2019 | 07:02 PM
bigdooly's Avatar
Sounds good. I bought it out of New Jersey.
I'll pm you my cell #.
Old Oct 12, 2019 | 01:02 PM
bigdooly's Avatar
Motor
Motor is running no unusual noises, smoke, sounds healthy.
I had to pull a carb of the shelf to get if running as original too gummed up
This carb's not perfect but for demonstration purposes gets the job done.
Amarion58
Feb 15, 2017 07:26 PM
67Rocket
Dec 30, 2016 09:10 AM
71 delta88guy
May 28, 2016 08:03 PM
kmaysob
Apr 16, 2012 02:56 PM
hardtop/ragtop
41
Nov 15, 2011 03:54 PM
