77 Cutlass Rear window molding
Old Oct 2, 2024 | 01:21 PM
Bluerae's Avatar
Looking for stainless steel rear window molding for a 77 Cutlass Supreme Brougham. See attached picture. Only need left (drivers side) half but would buy full set.
Old Oct 6, 2024 | 04:36 PM
joes_olds's Avatar
I didn't realize 77's had the stainless around the rear. Prior years seem to be the same color as the top. Google search shows both colored and stainless on 77's. You might try going for the matching color ones assuming the vinyl top is factory color (or you paint). Just giving you some different options.
Old Oct 6, 2024 | 06:30 PM
Paladin31's Avatar
Mouldings
To the best of my knowledge, the bright mouldings were used on Supreme’s without landau tops, the landau models had painted pebbles steel mouldings
Brett
ps. Which isn’t to say someone at some point may have installed bright moulding on a landau top car
also none of front or rear windshield mouldings are stainless, they are anodized aluminum
Old Oct 7, 2024 | 04:51 AM
olds3442's Avatar
Molding
I have a complete set of painted that came off sons race car we removed vinyl top and went to polished message if iinterested
Old Oct 7, 2024 | 08:19 AM
Bluerae's Avatar
Thanks, I guess it's anodized aluminum. It is definitely original. The anodized aluminum moulding came with the white landau roof when my mother-in-law bought the car new from the dealership in July 1977.
Old Oct 7, 2024 | 08:22 AM
Bluerae's Avatar
Thanks but I already have a set of painted moulding that I pulled off a wreck at the wreckers. Really hoping to match the original with the stainless/aluminum moulding.
Old Oct 7, 2024 | 09:51 AM
Bluerae's Avatar
Thanks, may have to do that if I am unsuccessful in finding the bright ones.
Old Oct 7, 2024 | 10:43 AM
Paladin31's Avatar
Info
thanks good to know
best luck in your search
Brett
Old Oct 8, 2024 | 06:16 PM
joes_olds's Avatar
No idea if this site is reliable or even active. But they list your parts assuming the 73-77 A-bodies used the same parts. Could be worth a shot.
https://www.montemania.com/genuinegmpartscentral_1973%20-%201977%20A-BODY.htm
From a 1976 Cutlass.
Old Oct 9, 2024 | 08:17 AM
Bluerae's Avatar
Thanks Joe, I'll give it a shot.
Andrew Anatian
May 11, 2025 01:22 AM
scrappie
Sep 13, 2020 02:20 PM
Duneracer
Oct 9, 2017 07:57 PM
drepreston1
Aug 11, 2013 04:25 PM
rz66046
Nov 25, 2012 07:59 PM
