71cutlass convertible ABS plastic top rail
Hello All,
I am looking for a driver side rear door ABS plastic top rail for a 71 convertible. I believe 70 thru 72 would work? Any suggestions, I only need the top rail.
Thanks in advance.
Don
Thanks in advance.
Don
I believe the OP is referring to the rear interior "side panel" upper piece that is shown in the pic below. Nobody makes these so it's typical to need them when getting new rear interior side panels for a convert as Legendary, etc have to have them to install onto their new panels.
The one in the pic below is a bit broken up with some pieces missing where the inner sweeper was stapled on......probably not a good candidate for the guy looking here. I'm just posting the pic to show an example of what I bet he's looking for.
These are actually made of fiberglass and they break easily. I WISH they were ABS plastic since they would then be much easier to make solid repairs to.
70Post is correct that is the part I am looking for. I have heard that they came in metal for some years and ABS others. I took the description from the OPGI catalog (they call it an ABS top rail) that show the entire assembly (I only need the top rail). I have not had any luck contacting PUI as the only phone numbers I can find are for their distributors, I will continue to look for that number. Any help locating their number would be helpful to me. Thanks for all your input.
Don
Don
epinkston
May 14th, 2014 09:40 PM
