71 442 W30 4speed no a/c water pump
Check the Oldsmobile page on https://www.vintagepartsource.com , large list of parts suppliers, one of them may have that water pump
Would like the one with large 2 please. My research stated that’s correct and the red one in you pictures showing it is perfect. Btw. Is is 5 in or 51/2? Thanks. And I need to know how to pay. All the best. Mark.
Red #2 pump
If your 221 dated car with 207-115 approximate generaly accepted component build dates is one your shopping for , that date code 8 may not be the One you want
#1 pumps casting 408328 are 5.1 flange dimension & can accept large 4.8 HDC Impeller
#2 pumps casting 408329 are 5.6 flange dimension & can accept large 4.8 HDC Impeller
#3 pumps casting 407536 are 6.1 flange dimension & CAN NOT accept the large 4.8 impeller without machining the housing
Common Olds flange dimensions of 5.1 , 5.6 , & 6.1 are all rounded up .038 & shown here with 71-72 #1 , #2 , & #3 pumps side by side
Water pump #408329 available
oldsplant6@gmail.com
71_ 72 W 30
'70 -W-30
Oldsplant6@gmail.com
limegreen71w30
September 22nd, 2014 08:22 AM
