69 w30 4-speed
I have around 60 Muncies.I could build you a trans. with correct casting #'s.I'm also an Auto gear dealer,so it would be easy to build you an M-22 in the correct GM case.Just a thought.If you're doing a conversion,I may also have the correct shifter and linkage,pedal assembly,etc.
