69 center console repair piece needed
Old Oct 8, 2023 | 07:05 PM
Ap6954's Avatar
(No longer need parts) Might be a bit of a long shot but I am trying to save a center console for a 69 4 speed. I am looking to see if someone has a trashed console that may have a salvageable rear lower section they are willing to sell. I think the 64-69 is the same. See picture below of what I need. Any color will work since I am going to dye it when repaired. PM me if you have something.
Old Oct 9, 2023 | 12:05 AM
cfair's Avatar
This may not be helpful, but one thing you can do in case you can’t get the replacement you’re looking for is to cobble up (aka cut-to-fit) a piece of plastic for the void you’re looking to fill. Glue it in. Or, if it’s in a place that people will kick, support it with some L or angle brackets for strength.
Then skin the entire console in leather or a matching (probably Madrid grain) vinyl. I had to do this with my 66 98 convertible door panel switch arms. I never noticed the clean, but not correct, more or less ever. It might look different from factory, but it looks consistent & right.
Just a thought
Chris
Old Oct 9, 2023 | 12:07 AM
cfair's Avatar
Oh - this is a good time to consider where you might want to add cupholders on the side of the console and maybe some Impala belt buckle retainers.
I just added the buckle clips and am very happy with the idea that they won’t damage my (now rare) console every time someone gets in/out.
Cheers
Chris
Old Oct 9, 2023 | 07:08 AM
Ap6954's Avatar
Thanks for the ideas Chris! The car this will go in is a #’s matching pretty original car so I’m gonna try and keep it looking original if I can. We will see what turns up. They repop the plastic lower section, but I love a challenge to try and save things!
Old Oct 9, 2023 | 08:42 AM
Paladin31's Avatar
Lower auto case
I have a light metallic blue lower 67-9 auto console body that’s very nice. will get a few pics posted for you in next few days when I can
perhaps you can get pieces from that
Brett
Old Oct 10, 2023 | 11:40 AM
Ap6954's Avatar
Brett
Thanks Brett. I think the auto consoles are a totally different shape though. More squared off in the back. Send a pic and I’ll check it out. I do have some old kick panels that I might be able to get some pieces off and make a wooden buck and then heat the plastic kick panel piece to get it to bend into the shape I need.
Old Oct 16, 2023 | 06:52 AM
Ap6954's Avatar
No longer need parts. Made the repair with some old kick panel pieces and heat to get the curvatures right. Thanks anyways to those that looked for stuff.
Old Oct 16, 2023 | 07:47 AM
67OAI's Avatar
Old(s)GuysRule
Nice looking repair!
Old Oct 16, 2023 | 10:13 AM
Ap6954's Avatar
thank you sir! I love saving original pieces. I love the SEM texture spray to restore the grain look on these kinds of pieces. Once I re flock the console and reassemble will be good as new.
Old Oct 16, 2023 | 07:45 PM
Paladin31's Avatar
Repair
Great job sir
Old Oct 17, 2023 | 03:45 AM
fleming442's Avatar
What did you use for glue? I thought the kicks and console were dissimilar plastics.
It turned out awesome! I need to repair my original, but just bought a TPP base.
Old Oct 17, 2023 | 06:33 AM
Ap6954's Avatar
The kick panels I stole some material from were actually from a parted out 2004 mustang we had leftover parts from. I probably used about 5 pieces to make all the repair pieces. I used Gorilla 2 part epoxy to glue it all up. That stuff does well with plastic and lasts in hot environments. Used gaffer tape to hold it together while I glued.
Once i glued it all up I carefully sanded the glued edges to knock them down flat trying to save as much grain as I could. Then used some plastic body filler to smooth it out.
Finally a couple coats of SEM texture spray to recapture the grain look and then SEM landau black.
Old Oct 17, 2023 | 06:47 AM
fleming442's Avatar
Interesting. Thanks
CleanCutt
Apr 2, 2022 07:15 AM
72455
Feb 26, 2019 09:21 AM
jgrimmy
May 9, 2016 08:56 AM
lass4ken
Feb 24, 2013 04:57 PM
kbdecatur
Apr 30, 2012 05:36 AM
