68 Cutlass/442 Passenger lower quarter patch panel
This is the only spot of rust on the entire car, and it's killing me.
I know this is a long shot, but I'm hoping someone out there bought a full quarter and only needs/needed the upper or rear section, as I only need the lower forward. I just have a small amount of rust bubbling up on the passenger side of my 68 Holiday Coupe. It starts just under the wheel arch trim at the very bottom, extends back probably 4-6 inches, and only goes up a few. But of course that is what I can see. So, I would really need probably 6" up and 8-10" back if someone has it. If you've got less, I can probably work with that as well.
I know a company used to make those patch panels, but I can't seem to find them anymore.
Thanks in advance
Thanks in advance
I've never seen a panel for a lower rear 68-69 1/4, only the lower front fender. It's a fairly easy piece to fabricate. The downside is when you strip that paint you're going to find it's worse than it looks
