'68-9 INTAKE J-398662 or 405233
Old Aug 24, 2013 | 12:42 PM
Octania's Avatar
Bought another "uncracked" intake 398662
It's cracked in the usual place between the large carb bores.
While serviceable, the buyer is spending a lot for a conversion and wants perfection.
I have parts to trade, or cash.
You must have it verified uncracked. Blasted clean is best. I need it right away. Buyer wants conversion done in 4 weeks and we already burned 1 week getting the last one blasted clean only to find a crack, and the next one was clean already but also cracked.
http://www.ebay.com/itm/130971415043...84.m1439.l2649
DAMMIT
If anyone wants the red one, or parts off it- TVS, thermostat housing, CHOKE COIL, let me know, I need to recover some of that fundage. Anything.
Old Aug 24, 2013 | 12:53 PM
Just a thought, what about welding it and machining it back down?
Old Aug 25, 2013 | 08:30 AM
Octania's Avatar
Well, if it ain't broke, don't fix it, right
I mean, it's cracked... but not unserviceable
therefore not "broke"
Welding cast iron is iffy at best. Machine shop suggested drilling a hole at the end of the crack and fitting it with a plug, to stop the crack from propagating.
No leak thru to hot air crossover. Just a crack from one side of the A/F plenum to the other.
The point is the buyer is spending a lot and expects an uncracked unrepaired part... which are getting hard to find...
Old Aug 25, 2013 | 12:56 PM
oldsmobilty's Avatar
I have a 398662 intake. Where exactly should I look for the crack?
Old Aug 25, 2013 | 07:52 PM
Octania's Avatar
anyone Should be able to spot these cracks, after magnaflux
The red intake had a crack the naked [reading glasses] eye could see; magnifying 7x loupe made it obvious.
Vertical crack, right between the larger [aft] carb bores, at the thinnest spot.
Old Aug 25, 2013 | 07:57 PM
I will get it cleaned up and double check but I believe mine is good.
Old Aug 27, 2013 | 07:08 PM
gaerte04's Avatar
I have one also if the other does not work out. The problem is I don't have the time to get it blasted and checked. Visually it appears to be in great condition. Date code 299.
Old Aug 27, 2013 | 07:22 PM
Hopefully I'll have mines blasted tomorrow but it looks fine.
Octania
Jun 13, 2022 08:07 AM
Octania
Aug 25, 2013 08:14 PM
442_1972
May 30, 2013 11:20 AM
ManCutty
Nov 2, 2011 06:57 PM
Boldsmobile
Nov 2, 2011 06:02 PM
