67 442
Old Oct 24, 2021 | 12:42 PM
66 W 30's Avatar
67 442
Looking for braces for 67 442 that goes from rear upper control arm to rear lower .. I have included pix of correct one it is the black one on the right need two. Also looking for correct jack base that will fit pix attached,and finally a good used set of exhaust manifold for 67 with heat risers in tact
Old Oct 24, 2021 | 09:14 PM
edzolz's Avatar
Location?
Old Oct 24, 2021 | 09:38 PM
66 W 30's Avatar
67 442
Chicago
Old Oct 25, 2021 | 06:56 AM
67OAI's Avatar
Old(s)GuysRule
66 W 30, you do know that Oldsmobile did not use the control arm braces on any of the 64 thru 67 442s; so why try to use the GM product when aftermarket braces are everywhere?
Old Oct 25, 2021 | 08:07 AM
66 W 30's Avatar
67 442
Thanks ..I did know that but we decided to put on car .. I did pick up a nice clean set of originals.
Old Oct 25, 2021 | 09:56 AM
67OAI's Avatar
Old(s)GuysRule
Glad you found some. You would think that the factory would have put them on all 4 speed cars like Pontiac did on the GTOs. Would have saved many ripped out welds on that rear upper cross member...ask me how I know!
Old Oct 25, 2021 | 02:05 PM
66-3X2 442's Avatar
How far back did Pontiac use the braces? I've taken many many many 66/67 442's apart and never saw a set on them as you said.
Old Oct 25, 2021 | 02:13 PM
Andy's Avatar
I have taken many 65-66 gtos apart and do not recall ever removing a upper to lower control arm brace. Swapped out several rear ends on the goats as well. 65-66
Old Oct 25, 2021 | 02:17 PM
lemoldsnut's Avatar
Sent you text pics of the parts you asked me for.
Larry
Old Oct 26, 2021 | 04:47 AM
newmexguy's Avatar
Should have Jack Base
Clean southern NM metal
Dave S
Old Oct 26, 2021 | 07:32 AM
67OAI's Avatar
Old(s)GuysRule
Mike and Andy, maybe the braces were not factory installed on the GTOs as I thought. I do remember seeing a set on a '67 GTO while it was up on the lift in a service station many years ago; could be the owner put them on.
66 W 30
Aug 21, 2021 10:36 AM
sammieolds
Jul 1, 2014 05:08 PM
UNHLAW2016
Jun 7, 2014 08:54 PM
springbryan
Apr 26, 2014 04:27 PM
67442nut
May 21, 2011 05:35 AM
