***EDIT**** Fusick carries the flatter style shown below, but there IS another style of clip that is used on the driver's side that is smooth on top and uses separate push pin connectors to hold them in place. Any lead on those would be appreciated.
These may be used on other years of Toronados (Toronadii?) but I’m not sure… The snap in clips that hold the wiring harness and hoses in place over the inner fenders are what I need. While later Cutlass clips will work, the Toro clips are lower and sleeker looking, and I’d just rather have the original style if they can be found. Reproductions/links to purchase are welcome. Pictures of what I need are below - Toro in front, Cutlass behind. I could use 5 of the Toro clips if you have them. Thanks!
I think Fusick had them at one time? I replaced them on my 69 in early 90s. It's always possible the 66-7 are different from the later cars.
Yes! Somehow I overlooked them when searching before, or I used the wrong term. Now I just need to order enough stuff to make the $15 shipping charge worth it....
