'66 442 Pulleys
Old Dec 24, 2020 | 07:56 AM
Rob Snook's Avatar
'66 442 Pulleys
Restoring by brother-in-laws old '66 442 - wrecked front end 25+ years ago. Looking for water pump and crank - 3 groove and 4 groove pulleys - car has AC, PS, AIR.
Old Dec 24, 2020 | 08:11 AM
lunaboy's Avatar
The Rocket Astronomer
i have everything except the 4 groove ,
what is your location please
Old Dec 24, 2020 | 05:43 PM
Rob Snook's Avatar
i am in newton nj 07860.if i can get these i would be happy
Old Dec 24, 2020 | 05:50 PM
Rob Snook's Avatar
1966 pulley
someone had last year a set of 4 groove pulleys
Old Dec 24, 2020 | 05:53 PM
Rob Snook's Avatar
does any body know danktx because he had a set last year in feb 20019
Old Dec 24, 2020 | 06:02 PM
Rob Snook's Avatar
1966 pulley
what do you want for them shipped to newton nj 07860
Old Dec 25, 2020 | 03:00 PM
2blu442's Avatar
Rob, I may have some 4 groove pullies. Is his car equipped with the California emissions? I've also got A.I.R. emissions parts if your missing anything.
John
Old Dec 25, 2020 | 03:52 PM
lunaboy's Avatar
are you after a 3 groove set or 4 groove set
Old Dec 25, 2020 | 05:32 PM
Rob Snook's Avatar
i do not know , ac is out far enough to be a 4 groove pulley.i have a 3 groove on water pump and ifb i move the ac backon the wronge side of the top bracket with spacers i can make a 3 groove work
Old Dec 25, 2020 | 05:33 PM
Rob Snook's Avatar
i want both so in can get this worked out
Old Dec 25, 2020 | 05:34 PM
Rob Snook's Avatar
and i do not have any of the air stuff
Old Dec 25, 2020 | 05:36 PM
Rob Snook's Avatar
i do not know how to add photos .
Old Dec 25, 2020 | 05:38 PM
Rob Snook's Avatar
it this time i only have a 2 groove crank pulley
Old Dec 25, 2020 | 05:41 PM
Rob Snook's Avatar
can some tell me how to add a photo to this so you all can see what i have
Old Dec 25, 2020 | 05:52 PM
Rob Snook's Avatar
just to let you all know this has ben sitting in side scent 1989 . it only has 44000 miles. runs like new. got hit up front. i will need all the ac stuff lines and other stuff. looking for front end parts.
Old Dec 26, 2020 | 08:21 AM
nicks1966's Avatar
Here is a pulley chart
crank pulley is 391434 code JD
Water pump is 391435 code JK
power steering is 394678 code JM
air inj is 390272 code JS
the alternator is 1949533 it a single groove could not find any code listed
the AC compressor is 6550456 could not find any code listed for it.
Old Dec 26, 2020 | 09:05 AM
2blu442's Avatar
Rob, if your going to use the factory AC parts then you may not need the 4 groove pulleys. Unless your car also has the air pump for California emissions the three groove pulleys will work and provide what you need. They will have enough belts and they will line up if you have the correct parts. See the diagrams Nick uploaded to see where things go on your engine.
To attach photos click on the little box with the mountain on it, just to the right of the paperclip. That will open a window allowing you to select photos from your computer. There is a chance it won't load if your photo is too large, but that should be the only hiccup to watch out for. Let us know if you still have problems.
Old Dec 26, 2020 | 09:24 AM
Rob Snook's Avatar
as of wright know the only pulleys i have is this on the water pump 39114jh got 2 of them they are 3 groove and on the crank 389645jb that is a 2 groove that looks like gm flatten the 3rd groove .the car has factory air on left side and power steering and alt on right side.
Old Dec 26, 2020 | 09:27 AM
2blu442's Avatar
OK, so you need the three groove pulleys for power steering and air conditioning. Don't confuse Air Conditioning with A.I.R., the second is for the air pump California emissions required.
Nick, can you post the page he needs?
Old Dec 26, 2020 | 09:32 AM
Rob Snook's Avatar
is there a space in the pulley groove between the 2 and 3 groove. My ac is space out for a 4 groove or a space between 2 & 3. Rob
Old Dec 26, 2020 | 09:35 AM
2blu442's Avatar
There's a number of subtle differences between the different pulley combinations. Some have spaces, some have thick metal between them. I'd encourage you to find the correct ones for your setup and go with them. Otherwise you'll likely have problems later on. If the pulleys alignment isn't perfect you'll eat up belts and maybe even throw them. Ask me how I know!
Old Dec 26, 2020 | 09:36 AM
Rob Snook's Avatar
we all been there
Old Dec 26, 2020 | 09:39 AM
Rob Snook's Avatar
did you have the 4 groove pulleys ?
Old Dec 26, 2020 | 09:52 AM
2blu442's Avatar
Rob, the AC compressor will line up with the correct 3 groove pulleys. The only need for 4 groove pulleys would be if your car had California emissions installed when it was new, the fourth groove being for the air pump. If your not sure check out the attached photo. The California emissions cars all had holes drilled and threads tapped for the A.I.R. system. If Nick doesn't have the right reference for your pulley numbers/letters I'll see if I can located my 1966 Assembly Manual.
Old Dec 26, 2020 | 10:10 AM
nicks1966's Avatar
here is the correct chart.
the 389645 is supposed to be a three groove pulley. Did it get smashed in the wreck
those are the same pulleys I have for my 66, just had some powder coated I will get you pictures a little later.
Crank is 389645 code JB
WP is 391114 code JH
PS is 384678 code JM
Old Dec 26, 2020 | 11:32 AM
nicks1966's Avatar
Old Dec 26, 2020 | 11:55 AM
newmexguy's Avatar
Could have you fixed up with all the a/c lines and condenser, if you had been looking 5-6 months ago. Yard just crushed it.
I do have the upper and lower radiator support sections.
Old Dec 27, 2020 | 07:06 PM
lunaboy's Avatar
Just sold my last spare three groove crank pulley, but i have two WP 391114 code JH if you need one.
Old Dec 29, 2020 | 12:49 PM
Rob Snook's Avatar
66 442 pulleys
Old May 2, 2022 | 07:11 PM
matefis's Avatar
Hello,
Long shot, I know but is this pulley still avaialble?
Originally Posted by nicks1966
Old May 2, 2022 | 07:12 PM
  #31
matefis's Avatar
still available?
Old May 2, 2022 | 07:30 PM
  #32
lunaboy's Avatar
yes
Old May 2, 2022 | 08:05 PM
  #33
matefis's Avatar
yes
great, sent you a message
Andy
May 4, 2020 06:32 AM
lunaboy
Mar 6, 2015 08:52 AM
mike's88
Feb 7, 2012 07:59 AM
diphead
Sep 17, 2010 01:31 PM
