65-66 Ninety Eight Rear Reading Lamp Bulb Cover & Radio Antenna
Hello all!
I have a 66 Ninety Eight and I'm missing the drivers rear reading lamp lens / bulb cover. Does anyone have one or know of another GM product that uses the same part?
Also, my non powered antenna was snapped off before I bought her. I'd like to find a replacement if possible.
Thank you!
-Chris
Thank you!
-Chris
Chris,
Welcome. I also have a 66 98, but no rear (quarter lamp- is that what you’re referring to?) lamp, since my top goes down. From what I’ve seen over 40 years in 65-66, Olds used two rear lamp styles - a rectangular one maybe with an Olds logo and a circular one which looked more generic GM. It might be a good idea to post a picture of the housing so we’ll understand what you’re looking for, or take a shot of the right one so we know. Match what you got, but if it won’t look weird, I think you’ll find may reproductions of the circular one.
The non-power (right front fender mounted, correct?) was common to many Olds of that period. If I had your problem I’d hit eBay with a search for “Oldsmobile fixed antenna mast” or something like that.
Also be aware that at the cost of bodywork and upgrade, Olds made a cool power antenna option which was desirable for these cars, but it was mounted on the right rear fender. So you’d have to fill and paint the front fender hole, get all the parts (switch, power wires, signal cable and motorized mast assembly) - then cut the correct size hole in your right rear fender. I did this on my ‘66 Starfire and was very happy with the upgrade. The mast and cables and stuff are all sort of large GM generic from that day 65-66 Caddy, Buick, Pontiac, Olds so you can potentially swap in other brand equipment. The only piece that’s really Olds-unique is that under dash power antenna switch.
I’ve had these cars for a long time, when you can’t sleep and would like to learn more, maybe some of my posts might help you.
Cheers
Chris
Cheers
Chris
Chris,
Cheers
Chris
Cheers
Chris
Hi Chris!
Thank you for the great info!
After reading your reply, I went on eBay and searched around for the courtesy lamp lens. I found an OE GM unit for $10 shipped. If anyone in the future needs to replace the round one, the GM PN is: 4765600
Next was the antenna. I found the antenna plastic nut but no complete setup or mast. I found universal units that would work for my application but they don't look correct. I'll keep an eye out for a good used one that matches the factory unit.
Thank you again! I'll definitely look through your posts and see what I can learn.
-Chris
https://www.2040-parts.com/nos-oldsm...8-69-i2004277/
Do you happen to know the part number for the manual non power mast?
Thank you!
-Chris
How much are you asking for your complete assembly?
Also, do you happen to have a battery hold down setup for '66 88, 98, or Starfire?
Thank you,
-Chris
Check with Fusick www.fusick.com on the battery hold-down. I've gotten them for 64 FSC and I think one of my friends got one from them for his 1966 Starfire.
Thanks again,
-Chris
Tiberian Fiend
May 13th, 2019 11:22 AM
MudEye
November 21st, 2016 06:24 AM
