65-66 console shifter handle
Old Mar 2, 2024 | 02:17 PM
Buickguy67's Avatar
I am looking for the shifter handle for the Olds F85 auto console. I have the chrome shifter rod and linkage piece but no handle. I did somewhere about using the Ford shifter handle which I did buy but not sure how to connect it to what I have. Probably better to have the original handle. Any help or suggestions would be greatly appreciated. Thanks Gary
Old Mar 2, 2024 | 03:13 PM
harleyrules's Avatar
It looks like IMO your shifter is broken. It should have 2 "ears" on the top of shaft and a pivot point in the middle of the "ears" I know that's how my 64 shifter is anyway. Very common for the "ears" to break off. There is a company that makes a kit to use the shaft with a ball instead of the T handle.
Old Mar 3, 2024 | 07:36 AM
Buickguy67's Avatar
The shifter setup i have looks like this one and the T handle is what I need. Are you referring to the black tips on the end of the handle as ears?
Old Mar 3, 2024 | 03:26 PM
That is the shifter I am also referring to on the top of your shifter shaft you are missing the "ears" it is a broken shaft. I'll try to find a picture of what it looks like, I'm sure Joe probably has a picture available if I can't find one.
Old Mar 3, 2024 | 11:21 PM
nicks1966's Avatar
shifter and center shaft
shifter ears
Your shifter is broken like most of them , if your center shaft is not broken( most are ), shift works make a conversion to change it to a ball and not the original T-handle. I don't know how well the conversion works.
https://shiftworks.com/collections/c...le-replacement
Old Mar 4, 2024 | 07:11 AM
Buickguy67's Avatar
Ok thanks for the pictures and information, now I understand the ears thing that has been mentioned but never had seen pictures of them until now.
Old Mar 4, 2024 | 08:06 AM
Buickguy67's Avatar
My center shaft from what I can tell is not broken but looking at your picture I don't have the little piece at the top with the screw attached to it. So there is no way to repair the chrome shaft or adapt another handle or **** to it?
Old Mar 4, 2024 | 10:10 AM
This is pot metal. It is not easily repaired - at least not in a way that is functionally correct. There is a really nice unbroken 64-66 stick on ebay right now.
Old Mar 4, 2024 | 03:22 PM
dingusboy's Avatar
They are like hen's teeth. However, 1964 1965 Oldsmobile 442 Cutlass Original Automatic Trans Console Shift Handle | eBay
Old Mar 6, 2024 | 08:55 AM
RAG's Avatar
RAG
I have a handle with the buttons to sell separately, came off a broken shifter shaft. rgreen@Q.com
Old Mar 6, 2024 | 08:59 AM
Buickguy67's Avatar
I sent you an email regarding your shifter handle
Chuxter
Feb 21, 2024 07:18 PM
alsmith787
Jan 23, 2019 09:44 PM
88hurstolds
Jan 20, 2016 08:06 PM
johns65442
May 15, 2014 09:30 AM
2X72
Jan 16, 2013 04:26 AM
