I briefly looked at the bezels I have and there does seem to be a difference between RT and left, I saw no mark stating l or r but the mounting tabs among other things seem to be different. I think you need to remove yours and take detailed pictures.
Yes, that is correct. There is slight differences. At first they do appear to be the same but it is definitely the passenger side that I am looking for.
So since they are not marked I have no way of knowing what side is what without detail pictures.
Yes correct. I agree. I have discovered the differences by setting them side by side. It is the passenger side that I need. I need the headlight bezel for a passenger side 1964 Olds Cutlass. Let me know if you have one. Thank you
I wasn't able to find an L or R stamped on mine. But one thing I did notice that may help Oldsmaniac check his is that the top of the rings have the two bolt hole tabs closer together. Also the passenger side inside one will have the center bar attached further out. The area pressed in will be longer on the inside passenger side one. Maniac, let me know if you need to see any other views or measurements to verify which one is correct.
I have a very nice passenger side down here in Sebring. Please email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
