64 cutlass head light bezel
Old Feb 20, 2024 | 10:27 AM
Rob64cutlass's Avatar
Looking for 1 1964 Cutlass headlight bezel
Old Feb 20, 2024 | 10:44 AM
Oldsmaniac's Avatar
Right or left?
Old Feb 20, 2024 | 04:11 PM
Right or left?
I thought they were universal on the 64.... ill check and let you know.
Old Feb 21, 2024 | 09:24 AM
REO442's Avatar
Post a photo of the bezel. May have what you need.
Old Feb 21, 2024 | 07:25 PM
Will do. I'll get a photo on tomorrow
Old Feb 22, 2024 | 03:58 PM
Passenger side
Old Feb 22, 2024 | 04:04 PM
Oldsmaniac's Avatar
I briefly looked at the bezels I have and there does seem to be a difference between RT and left, I saw no mark stating l or r but the mounting tabs among other things seem to be different. I think you need to remove yours and take detailed pictures.
Old Feb 22, 2024 | 05:26 PM
Yes, that is correct. There is slight differences. At first they do appear to be the same but it is definitely the passenger side that I am looking for.
Old Feb 23, 2024 | 03:54 AM
Oldsmaniac's Avatar
So since they are not marked I have no way of knowing what side is what without detail pictures.
Old Feb 23, 2024 | 08:40 AM
Yes correct. I agree. I have discovered the differences by setting them side by side. It is the passenger side that I need. I need the headlight bezel for a passenger side 1964 Olds Cutlass. Let me know if you have one. Thank you
Old Feb 23, 2024 | 02:43 PM
oldolds88's Avatar
look on the tabs for the screws,should be l and r
Old Feb 23, 2024 | 04:26 PM
2blu442's Avatar
I wasn't able to find an L or R stamped on mine. But one thing I did notice that may help Oldsmaniac check his is that the top of the rings have the two bolt hole tabs closer together. Also the passenger side inside one will have the center bar attached further out. The area pressed in will be longer on the inside passenger side one. Maniac, let me know if you need to see any other views or measurements to verify which one is correct.
Old Feb 26, 2024 | 07:21 PM
wr1970's Avatar
I wonder if a wagon is the same!
Old Feb 27, 2024 | 05:06 AM
oldolds88's Avatar
yes, wagon has the same front end
Old Feb 28, 2024 | 05:28 AM
ROCKETMAN269V's Avatar
I have a very nice passenger side down here in Sebring. Please email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
Old Feb 12, 2025 | 11:21 AM
Pics sent. Thanks, Bob.
Old Feb 17, 2025 | 08:50 AM
Question ?
Rob, did you ever get the pics that I sent? I haven't hears back from you. Please let me know. Thanks, Bob.
Old Feb 19, 2025 | 10:15 AM
Dave442's Avatar
I have this one only… not sure which side….maybe someone can identify it as LH or RH….you can have it cheap, just trying to help out…you can text me at 661-203-6953 for more info. Thanks, Dave
Zabkarian
Nov 18, 2017 05:56 AM
53Ragtop
Apr 11, 2017 02:55 PM
GEARMAN69
Jan 12, 2016 09:17 AM
esk
Nov 13, 2012 11:50 AM
Lows1979Cutlass
Jul 29, 2011 05:14 PM
