455 misc. engine parts
When I bought this short block it was pretty well stripped. I need a GOOD 5 qrt. pan (if they ever made one) & pick up .... damper..... flex plate that will work with a 4l80e ..... 2 groove pulleys for crank and alternator and a good thermostat housing. I'm probably forgetting something but that will do for now. Thanks in advance, Dave
I have numerous engines, already disassembled, and any factory parts that you may need. A stock flexplate should work for you. You really need to match the pulleys with whatever brackets that you are using. Email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
The Toro pan is overrated. Keep in mind that it was designed primarily to clear the driver side differential and drive axles. There is a notch to clear the passenger side axle shaft. This traps oil in the front of the pan where it then can get whipped into a froth by the crank throws. The fact that it has extra capacity doesn't mean that you can use that capacity.
The_Jeremiah
February 7th, 2017 07:11 PM
nine8
March 25th, 2015 02:41 PM
