455 misc. engine parts
Old May 9, 2018 | 06:50 PM
Gascoop's Avatar
When I bought this short block it was pretty well stripped. I need a GOOD 5 qrt. pan (if they ever made one) & pick up .... damper..... flex plate that will work with a 4l80e ..... 2 groove pulleys for crank and alternator and a good thermostat housing. I'm probably forgetting something but that will do for now. Thanks in advance, Dave
Old May 9, 2018 | 07:19 PM
442crzy's Avatar
PM sent
Old May 10, 2018 | 04:22 AM
ROCKETMAN269V's Avatar
I have numerous engines, already disassembled, and any factory parts that you may need. A stock flexplate should work for you. You really need to match the pulleys with whatever brackets that you are using. Email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
Old May 11, 2018 | 03:57 PM
Gerald Nickels's Avatar
The Toro pans are 5 qt. 1 in filter, total 6 qt.
Old May 11, 2018 | 04:14 PM
Gascoop's Avatar
Thank you sir, I appreciate the info, need all the oil capacity I can get w/o a race type pan.
Old May 12, 2018 | 05:01 AM
The Toro pan is overrated. Keep in mind that it was designed primarily to clear the driver side differential and drive axles. There is a notch to clear the passenger side axle shaft. This traps oil in the front of the pan where it then can get whipped into a froth by the crank throws. The fact that it has extra capacity doesn't mean that you can use that capacity.
Old May 12, 2018 | 11:20 AM
Gascoop's Avatar
My error for not being more specific, no, I don't want the Toro pan. I wasn't sure if Olds made a stock 5 qrt. capacity oil pan other than the Toro pan.
Old May 12, 2018 | 12:43 PM
RetroRanger's Avatar
72 Olds CS
If you have the room a big oil filter like Baldwin b9 adds some extra capacity
Old May 12, 2018 | 01:11 PM
Gascoop's Avatar
Yes sir thanks, I've got plenty of room, that B9 cross references to a ton of other filters also. I'm a fan of Wix filters so I'm sure they make a longer version.
The_Jeremiah
Feb 7, 2017 07:11 PM
dedsleds
Jan 9, 2014 11:53 AM
nj_cutlass72
Dec 27, 2012 07:57 PM
t/a formulas
Jan 11, 2011 12:56 PM
