4 row radiator top plate cover 1972 cutlass
Old Aug 3, 2016 | 02:56 PM
my72olds's Avatar
As title says I'm looking for the top radiator cover , (no show car here but i dont want any rusted beat up parts ) for a 4 row I'm adding to my 72 .
Anyone one with one for sale ( need it shipped to tx) I can be contacted by email
My72olds@yahoo.com
Old Aug 3, 2016 | 03:44 PM
You do know these are reproduced and aren't all that expensive? 119.00 from Parts Place
Old Aug 3, 2016 | 05:10 PM
jensenracing77's Avatar
X2. I can spot one in a second on a high end restoration but if you are not looking for that then just go with the repop. (difference is minor) Repop and original are the same price if you can find an original but the original will likely need a repaint.
Old Aug 3, 2016 | 05:27 PM
11971four4two's Avatar
MOTORHEAD
Hi 72
you will also want to look at the mounts
where radiator sits on core support
I have modified / bent the brackets on support and top plate to install 4 row rad in the past.
agri american engineering
Old Aug 3, 2016 | 05:35 PM
RetroRanger's Avatar
72 Olds CS
funkwagon455 posted a pic in another thread that showed the modified 2-3 core one with 4 core saddles (avialible on ebay) he modded it to be very similar to a 4 core...if you can weld thats another option
Old Aug 3, 2016 | 05:50 PM
72 Olds CS
edit heres the thread w pics and link to 4 core saddles on ebay
https://classicoldsmobile.com/forums...tml#post931613
Old Aug 3, 2016 | 06:24 PM
kevdog442's Avatar
Member
I have a couple for sale
File Type: jpeg
Old Aug 3, 2016 | 06:25 PM
kevdog442's Avatar
Member
Another
File Type: jpeg
Old Aug 4, 2016 | 10:38 AM
Eric, just for my curiosity, what is the tell tale difference?
Old Aug 4, 2016 | 11:12 AM
The only obvious thing is that the reproduction does not have the dimples for where to drill if it had the auxiliary transmission oil cooler. Other than that it is very hard to tell them apart.
Old Aug 4, 2016 | 04:03 PM
I enlarged both pics of the OEM ones that were posted but can't see where those dimples would be. Can you point them out?
Old Aug 4, 2016 | 04:10 PM
In post 7 you can see them. They are inline with the mounting bolt holes and one is close to to the middle and the other off set to the driver side. Maybe 12 inches apart. The dimple is small but very visible in post 7. I can't remember but I do not believe these are found on the 2 or 3 core top plates.
Old Aug 4, 2016 | 04:20 PM
Got it. Center and on the drivers side. I guess anyone who wanted it to look authentic (OEM) could press those dimples in if they were inclined to be perfect. Thank you for the information, now I can add that to my list of information. I'm going out on a limb and guess that ALL the 68-72 4 core rad top plates would have this feature? Or is it unique to the 70-72?
I'll have to check my top plate - it's for a 2/3 core rad. I don't remember seeing them, but that's likely because I never looked
Old Aug 4, 2016 | 04:37 PM
I believe it is only found on the 4 core. I don't think you could get the trans cooler on anything but a car with the 4 core.
Old Aug 4, 2016 | 04:47 PM
Makes sense, heavy duty cooling for the engine, heavy duty cooling for the trans.
That said, I've been told that a properly flowing 3 core is as effective as a 4 core. Thoughts?
Old Aug 4, 2016 | 05:57 PM
I would be willing to bet that is true on keeping a stock engine cool and likely a W-30 engine. I have no way to back that assumption up. But when it comes down to it, the 4 core has more surface area with another row of water so it would be capable or more cooling than a 3 core but how much I don't know.
Old Aug 8, 2016 | 04:59 PM
72 Olds CS
I just checked my 3 core top plate it has the dimples like the pic in post 7 (4 core plate)
442mark
Feb 5, 2018 07:19 PM
L69
Jul 29, 2012 08:04 AM
L69
Jul 26, 2012 07:24 PM
Indy_68_S
Nov 24, 2010 07:52 PM
nelsontj
Jun 16, 2010 03:48 PM
