394 exhaust manifold
Old Nov 9, 2013 | 11:01 AM
peteyb's Avatar
I need to find a passenger side exhaust manifold for my '63 394. Mine cracked right at the heat valve and broke off. I'll take the driver side too if you're not willing to separate a set.
Let me know if you can help.
Pete
Old Nov 9, 2013 | 11:54 AM
Oldskeeper's Avatar
Hi Pete,
The heat riser on a 63 394 is on the drivers side manifold and the cross over pipe wraps around and connects to the front of the passenger side manifold or you have dual exhaust and there is a blocker plate on the front of the passenger side manifold.
Where are you located?
Steve
Old Nov 9, 2013 | 05:37 PM
peteyb's Avatar
Yep my bad. I had a different orientation in my mind. It is the driver side that I need.
I'm outside Atlanta.
Old Nov 9, 2013 | 08:06 PM
deaddds's Avatar
So do you have dual or single exhaust? I should have a manifold for you. Drop a line at dead@mchsi.com.
Old Nov 9, 2013 | 08:55 PM
Pete, if you can't find one that works you might consider having your original manifold repaired. A good welding shop should easily be able to weld cast iron.
KQQLCAT
Jul 19, 2010 09:20 AM
bjtstarfire
Oct 20, 2008 03:48 PM
bbodine
Dec 18, 2007 04:24 PM
jeffrey
Nov 26, 2007 06:45 PM
KQQLCAT
Oct 29, 2007 03:47 PM
