330 spread bore intake
Old March 19th, 2019, 06:00 PM
lilhow's Avatar
Hi looking for early 330 intake for a quad carb. Southern Ontario area.
Thanks Jeff
lilhow is offline
Old March 19th, 2019, 07:06 PM
Old School Olds
tru-blue 442's Avatar
I have one from a 66 but shipping from TX may be prohibitive.
tru-blue 442 is offline
Old March 20th, 2019, 01:54 PM
lilhow's Avatar
Probably more than its worth to me anyway. I have a 65 cutlass convertible and want to get away from the 4gc carb on the cheap. I rebuilt a quad but intake has that small 4gc square bore.
Thanks for the reply
Jeff
lilhow is offline
Old March 20th, 2019, 03:55 PM
jcdynamic88's Avatar
you can use an edelbrock carb on your intake,in case you don't already know this
jcdynamic88 is offline
Old March 26th, 2019, 12:49 PM
lilhow's Avatar
Hi All and thanks,
I found one locally the only problem is getting the heater hose fitting out (rotted). The Eddy carb looks like it fits but it doesn't, even a square bore adapter had to be modified doesn't seal at the sides. Want to use a Quad with stock victaulic gasket.
lilhow is offline
Old March 26th, 2019, 01:46 PM
OLDSter Ralph's Avatar
Originally Posted by lilhow
Hi All and thanks,
Use a die grinder with a rotary file (bit) and grind a groove every 90 degrees or so.......just til you see the top of the female threads. Then drive a section inward. If you need to grind an additional groove in one section at 45 degrees, it should work. Get one section out and the rest should be easier.
OLDSter Ralph is offline
Old March 26th, 2019, 03:19 PM
If you don't care about appearances or the correct pocket for the divorced choke, any Olds 350 Qjet intake will also bolt to a 330.
joe_padavano is offline
lilhow
July 26th, 2018 09:33 AM
Roger60
March 18th, 2016 08:02 AM
67Rocket
May 26th, 2015 06:19 AM
belairbob
August 20th, 2011 06:58 AM
archerbob
August 19th, 2011 02:35 PM
Quick Reply: 330 spread bore intake
