330 spread bore intake
Old Mar 19, 2019 | 06:00 PM
lilhow's Avatar
Hi looking for early 330 intake for a quad carb. Southern Ontario area.
Thanks Jeff
Old Mar 19, 2019 | 07:06 PM
tru-blue 442's Avatar
Old School Olds
I have one from a 66 but shipping from TX may be prohibitive.
Old Mar 20, 2019 | 01:54 PM
lilhow's Avatar
Probably more than its worth to me anyway. I have a 65 cutlass convertible and want to get away from the 4gc carb on the cheap. I rebuilt a quad but intake has that small 4gc square bore.
Thanks for the reply
Jeff
Old Mar 20, 2019 | 03:55 PM
jcdynamic88's Avatar
you can use an edelbrock carb on your intake,in case you don't already know this
Old Mar 26, 2019 | 12:49 PM
lilhow's Avatar
Hi All and thanks,
I found one locally the only problem is getting the heater hose fitting out (rotted). The Eddy carb looks like it fits but it doesn't, even a square bore adapter had to be modified doesn't seal at the sides. Want to use a Quad with stock victaulic gasket.
Old Mar 26, 2019 | 01:46 PM
OLDSter Ralph's Avatar
Originally Posted by lilhow
Hi All and thanks,
Use a die grinder with a rotary file (bit) and grind a groove every 90 degrees or so.......just til you see the top of the female threads. Then drive a section inward. If you need to grind an additional groove in one section at 45 degrees, it should work. Get one section out and the rest should be easier.
Old Mar 26, 2019 | 03:19 PM
If you don't care about appearances or the correct pocket for the divorced choke, any Olds 350 Qjet intake will also bolt to a 330.
lilhow
Jul 26, 2018 09:33 AM
Roger60
Mar 18, 2016 08:02 AM
67Rocket
May 26, 2015 06:19 AM
belairbob
Aug 20, 2011 06:58 AM
archerbob
Aug 19, 2011 02:35 PM
