307 Manifold Parts- choke tube, vacuum port
Here I go breaking things again. This is all off an 80's era 307. This time I'm in need of the choke heat tube assembly as well as a screw-in vacuum port from the manifold.
Also could use a metal wiring harness retainer/bracket that shares the valve cover bolt (RH).
Please email elcamino1970@hotmail.com or drop me a PM. Thanks
Below are pics:
Below are pics:
As far as the choke tube, check your salvage yard. Find the best one you can. You need to replace the gasket, too. I'm sure someone around here has spares. If you come up empty and are good with metal, you should be make a new one out of some flat steel stock, a tubing bender, and some fuel line.
If originality is not a concern, you may be able to find something that will work at a hardware store or NAPA. I go to ACE Hardware all the time for weird fittings, etc.
You can still order the tube that bolts into the intake GM# 412620, list price $20. The gasket is #22547859, about $3. The question mark shaped pipe is #559344, available from Vintage parts through GM dealers, about $20.
Actually never knew they were two pieces. In that case I just need the screw in ?-shaped tube as it rusted off. But if someone has a nice uncorroded set that's better. Thanks a lot for those p/n's Frank.
ROCKET VAPOR
February 8th, 2013 03:21 PM
