3.42 and 3.91 ring and pinion
Old Aug 10, 2024 | 07:15 AM
rickw30's Avatar
I'm looking for a nice set of GM 3.42 and 3.91 ring and pinion for a 588 carrier.
Thanks,
Rick
Old Aug 15, 2024 | 06:17 AM
rickw30's Avatar
Ttt
Old Aug 30, 2024 | 05:02 AM
rickw30's Avatar
Ttt
Old Aug 30, 2024 | 10:37 AM
cdrod's Avatar
Rodney
Contact Jim at JDRace.com, he goes by Monzaz here on Classic Olds. I purchased 3.42 gears, Eaton TrueTrack posi, bearings, & seals from him in 2014. He knows his stuff.
Rodney
Old Aug 30, 2024 | 12:20 PM
rickw30's Avatar
Thanks Rodney.
I called Jim and he doesn't have any GM sets.
I need Original GM for a 588 carrier.
Aftermarket doesn't fit.
Old Sep 9, 2024 | 01:38 AM
JLawrence's Avatar
Thanks,
Rick
I know someone in Monroe Wa that has I believe a 3.91 12 bolt open out of a vista if i remember.
Are you interested in the complete rear end or just gears I could get you in touch with Arne
Old Sep 9, 2024 | 02:08 AM
rickw30's Avatar
Either or ...
I appreciate it !
Old Sep 22, 2024 | 11:00 AM
JLawrence's Avatar
I sent you Arne's phone number in a private message
Old Sep 22, 2024 | 07:30 PM
rickw30's Avatar
Thank you !
Old Sep 22, 2024 | 08:33 PM
I thought I read that the Vista Cruiser used a larger diameter ring gear than the A-Body cars.
Old Sep 23, 2024 | 05:27 AM
ROCKETMAN269V's Avatar
[QUOTE=Fun71;1593933]I thought I read that the Vista Cruiser used a larger diameter ring gear than the A-Body cars.[/QUOTE
That is correct.
Old Sep 23, 2024 | 05:25 PM
CANADIANOLDS's Avatar
[QUOTE=ROCKETMAN269V;1593971]
That is correct.
can you explain the difference in diameter?
Old Sep 23, 2024 | 05:51 PM
[QUOTE=CANADIANOLDS;1594145]
It is a very minor amount. we had a set of gears for a vista that we were going to use in our race car. Nobody, at that time (~1983-84) made a spool for an Olds 8.5" type "O" rear end. We sent Henry's Axle in California the dimension's off of an 8.5 open carrier that we had laying around the shop. They made the spool and sent it to us and the ring gear literally fell onto it an was loose. We had to send them the posi carrier out of the car and they welded material at various spots around the circumference of the register of the pool, then re-machined it so the ring gear was a snug fit. The bolt circle also had to be modified a slight amount too. I have no idea why they made it just slightly bigger than the Cutlass rear.
Old Sep 24, 2024 | 02:55 PM
[QUOTE=ROCKETMAN269V;1594153]
Nice story but they aren’t any different.
the axle bearings are, but not the ring gear
Old Sep 24, 2024 | 04:34 PM
I did some web searching and apparently the rearend I was thinking of is the B-body O-Type with a 12 bolt cover and 12 bolt 9.3" ring gear.
https://classicoldsmobile.com/forums...xle-id-117494/
Old Oct 5, 2024 | 06:31 PM
rickw30's Avatar
Found a set of 3.91's.
STILL LOOKING FOR 3.42 RING AND PINION.
Old Oct 24, 2024 | 04:38 AM
rickw30's Avatar
Ttt
Old Nov 12, 2024 | 05:55 PM
rickw30's Avatar
Still looking for a set of 3.42's
Old Nov 13, 2024 | 06:25 AM
That is not correct. The Vista used the same center section as did any other Olds A-body from the same year. The differences in the Vista rear are larger wheel bearings and larger brakes (the backing plates are different to accommodate the 9.5" x 2.5" shoes).
alain
Jun 16, 2020 03:36 PM
Bob Kelso
May 18, 2014 05:13 AM
Napoleon1991
Mar 7, 2014 12:06 PM
warrior71
Jun 23, 2012 05:48 PM
