2.41 ring and pinion and axles for 76 rear
Old Mar 25, 2018 | 02:53 PM
DZAUTO's Avatar
I'm looking for a spare R&P as well as axles for my one owner (me) 76 Cutlass S, which has the original 2.42 posi.
I'm hearing some rearend noise, but I have not torn into it yet. I would like to have a spare 2.41 R&P (JUST IN CASE) as well as some axles. They are non C-clip axles (I know, I've been into it before).
Old Mar 25, 2018 | 07:54 PM
oldsmobiledave's Avatar
Want 2.41? Really?
Why do you want to keep 2.41 gears? Why not upgrade to a 3.08 or 3.23? The car must be torturously slow off the line.
Old Mar 26, 2018 | 04:16 AM
DZAUTO's Avatar
Actually, it's quite strong off the line. It has a built W30 spec 468 with a Richmond Street 5sp. The Richmond has a 3.27 1st gear, which works well with the 2.41, and 5th is 1:1, which is great on the Interstate.
I've got to get into the rearend in the next few days, and if I should discover that the R&P has issues, I'd like to have another gear set to replace it with.
Old Mar 26, 2018 | 05:40 AM
2.41 gears
I have the same trans in my 65 442 paired to a 2.73 Chevy 12 bolt. I had not considered that you were using a trans other than a 3 speed auto. Good luck with your project.
Old Mar 27, 2018 | 04:19 PM
DZAUTO's Avatar
I never learned how to drive a car with an auto tranny---------------just can't get the coordination worked out.
Powerm01
Jan 1, 2018 02:09 AM
1974IndyDelta12345
Feb 2, 2017 09:49 AM
67442nut
Jan 6, 2017 09:09 AM
oldspackrat
Aug 10, 2014 10:03 PM
agtw31
Jun 19, 2010 01:55 PM
