1982 Olds 98 Regency Brougham
Old Jan 1, 2014 | 10:04 PM
Machwest's Avatar
Is anyone wrecking an Olds same as above. I am chasing a left hand Opera Light (it has a small crack in it and only half glows), I am trying to keep it original and don't want to really put LED lights in it. Cheers Mike
Old Jan 1, 2014 | 10:22 PM
You can also use donor parts from 1983/84 Regency Brougham 4 doors. Too bad the Buick Park Avenue uses a shorter bulb or you could use it too.
Old Jan 2, 2014 | 04:18 PM
Machwest's Avatar
Also if anyone has a genuine radio/cassette player for 1982 Olds I am chasing one as well Cheers
Old Jan 2, 2014 | 05:47 PM
ThePackRat's Avatar
Big Daddy No Bucks
1984-85 Delta 88 Royale Brougham LS uses that style opera lamp as well.
Old Jan 2, 2014 | 06:51 PM
Lady72nRob71's Avatar
Can you post a picture of what it should look like or the dash opening?
I knew someone who might have one if it is the not the ETR2000 series (Euro style 1.5DIN).
Old Jan 19, 2014 | 05:09 PM
Paladin31's Avatar
Lighting the load
Are these what you were looking for?
Old Jan 20, 2014 | 11:21 AM
Brett, the 98 came in 2 trim lines - Regency and Regency Brougham. The lights you have are from the Regency and are located on the sail panel. They also aren't 'flourescent white' like the Regency Brougham, just regular incandescent that run off DC. Regency models had plain B pillars with no trim attached.
Regency
The Regency Brougham used longer lights framed by tall brushed stainless on the B Pillar. Also note the Regency Brougham had the 'Brougham' emblem on the sail panel. This fluorescent lighting also required a power inverter (located forward/upper DS rear quarter panel) to convert DC to AC.
Old Jan 20, 2014 | 03:59 PM
Machwest's Avatar
Brett, yes mine are the same as Regency Brougham as in picture cheersMike
Old Jan 20, 2014 | 04:18 PM
Paladin31's Avatar
E for effort, Sorry Mike
Thanks, Allan
Old Jan 20, 2014 | 04:53 PM
Paladin31's Avatar
Ok how about this one...
Old Jan 20, 2014 | 09:39 PM
Nope, it's not that either.
Old Jan 21, 2014 | 03:42 PM
Paladin31's Avatar
Now your just being persnickety Allan...work my poor fingers to the bone...
Old Jan 21, 2014 | 04:01 PM
Sorry Brett, not trying to be so I'll take my turn workin my fingers to da bone. This is what the EL lights were like and with trim. Sorry the pics are a little pixelated from downsizing the original image.
Old Jan 21, 2014 | 05:30 PM
Paladin31's Avatar
You light up my Life
You HAVE one? selling it are we? Machwest is looking for one...if you were unaware...
Even my shoes are wet from the sarcasm dripping on them ....
Old Jan 21, 2014 | 06:12 PM
LOL Brett. I can handle any sarcasm dripping, honestly I'd be more worried if your feet were wet from getting too excited at seeing the right part, and peeing yourself
No, I was just trying to post a picture of what Machwest is looking for in case someone scrolling through the thread sees it.
Machwest - These lights didn't really burn out all that often. Check and see if both are out or one is working. If one is working, obviously you need the light. But if both are out, there's a really good chance all you need is the power inverter to fix your problem. That happened on my 83 Regency Brougham and I had those lights out 2x before I realized they weren't the problem.
There's a small allen screw at the bottom of the trim bezel that has to be loosened (if you remove it don't lose it. Put it somewhere safe right away. Don't ask how I know about this). Access to the screw requires the front door to be open. Once that screw is loose you can swing the trim bezel out and lift the bezel up off the plastic base that holds it. The power inverter is on the drivers side of the trunk. You'll have to move the sound deadener panels to find it. Should be up to the left side of the trunk hinge. The inverter repair is covered in the Electrical Troubleshooting and Chassis Service manuals for the car.
I just did a quick search on the web and for 10 bucks + shipping you have the manuals for your car
1982 Chassis Service Manual/Electrical Troubleshooting Manual
Old Jan 21, 2014 | 06:41 PM
Paladin31's Avatar
Allan, the banter at the LEAST is always great my friend. It's what 99.9% of us are really here for, to learn, educate, enjoy the camaraderie. Like summer camp with really cool toys!
Brett
Old Jan 21, 2014 | 07:01 PM
Machwest's Avatar
Allan, I just fitted a new inverter and the right hand light is fine but the left hand looks like it has a crack and the bottom half and a small part at the top works cheers Mike
Machwest
Aug 14, 2014 05:32 AM
TimmyB
Cars Wanted
Feb 22, 2014 10:03 AM
Machwest
Dec 11, 2013 08:55 PM
Varmit
Ninety-Eight
Oct 2, 2012 07:09 AM
bigblue82
Feb 25, 2012 02:38 PM
