1972 Cutlass Water Pump Pulley Wanted
Old Jun 6, 2012 | 09:15 AM
Tony72Cutlass'S''s Avatar
1972 Cutlass Pulley Needed,
Please let me know if you have an extra, Needs to be functional and somewhat cosmetically sound. I can paint and sand.
Looks like i need a KO pulley since i have a longer water pump now.
see below
Old Jun 6, 2012 | 12:56 PM
Confirmed, We are pretty sure that i need the 1972 3 groove pulley that would have come on an A/C model car.
Anyone have a spare?
Old Jun 12, 2012 | 07:28 PM
Paladin31's Avatar
Pulleys
I have a few, none have that elusive KO on it. I checked the OPM it showed a 3 groove @5.75"dia, the two larger are slightly larger or smaller than 5.75, while the smallest is about 1/4" under. Take a look, let me know. Brett
Old Jun 12, 2012 | 07:31 PM
Hey Tony - get a measure on that middle one. It's a 3 greave pulley, and the bell is lower. Might fit. Compare measures as before. There will likely be more than just KO pulleys that will fit.
Old Jun 13, 2012 | 03:43 PM
Sorry for the late responses everyone! Been on the road for work... I wish i was home working on my car!
Hey Brett,
Thanks for the response!
Would you be able to grab a quick measurement for me on the middle one? This is the current measurement that i have
Al, Great catch! Hopefully i can get a couple measurements by the time i get home this week.
I asked Mike to take a measurement of his KO pulley, he said it's 2.875 on the dot. Hopefully one of these will line right up!
Old Jun 13, 2012 | 04:54 PM
Paladin31's Avatar
2.750 face to back of sheave rim, and 5-13/16 sheave Mac OD. So a washer or two under the sheave on the WOstuds should make it pretty close. Your thoughts?
Old Jun 14, 2012 | 05:09 AM
507OLDS's Avatar
If you got the long-snout HD-cooling pump,you would want a pulley with more offset,like the one on the left or possible the one on the right.Are there any numbers or markings on the new pump that you have?
Old Jun 14, 2012 | 06:25 AM
Hey All,
Thanks for your help, here are some pictures with measurements.
Old Jun 14, 2012 | 09:34 AM
507OLDS's Avatar
That does NOT look to be the longest snout available,so I am going to guess that you need the pulley on the left.I could check my 72 455 if/when I get a chance.It has the original pump & pulleys still intact.
Old Jun 14, 2012 | 11:08 AM
rcrac3r's Avatar
I'm looking for the same thing for my 72' 350. But mine does not have A/C. The water pump was replaced before I got it & it has this ugly silver pulley that is clearly not right for the motor. Looking from the side of the engine you can see the belts are off at an angle. Not sure if the PO put on the correct water pump.
Old Jun 14, 2012 | 12:06 PM
Post a picture of your setup. Between the three pulleys above too im sure you could find something.
Old Jun 14, 2012 | 03:34 PM
Paladin31's Avatar
Tony from your last group of pics-1st pic if total height from water flange to hub face is 5-5/8(I think) what did your old pump measure in same dimension? And is that a pic of your water pump as installed w/ 2 groove pulley on it with red arrows and 2.125d?
Old Jun 15, 2012 | 08:47 AM
Thanks in advance for all your help. SO i just measured my old water pump, and guess what? 5.1 inches tall. No wonder why it doesnt line up! (The new one pictured above was around 5 and 5/8'') Difference of around 0.525''
Old Jun 19, 2012 | 12:33 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If you have the 5.6" pump, KF water, KC crank, and KH steering will work together
If you have the 6.1" pump KB crank KO water and KH steering will work.
Old Jun 19, 2012 | 04:25 AM
507OLDS's Avatar
I checked my 72 455,which had AC & HD cooling,and it has the long 6" or 6.1" snout on the pump.
The dimensions that you gave of your new pump,sound like the dimension of the 70 HD-cool pump,which would then lead me to believe that you need the pulley in the middle.If I can get more time,I will try doing some mock-ups.J-Chicago has the applications correct.
Old Jun 28, 2012 | 08:38 PM
Dear All,
Got a great looking powercoated pulley from Mike. The pulleys line up REAL close. All i might need is a washer or two under the lip and it should be perfect.
What do you guys think?
Man, now i wanna have the rest of my pulleys powder coated...
Old Jun 28, 2012 | 08:57 PM
Aaaccckkkk! Tony
You had that balancer pulley off when you did the water pump/timing chain and didn't clean/paint it????
Old Jun 29, 2012 | 07:00 AM
507OLDS's Avatar
They make shims to go behind the water pump pulley,if you need to move it out a hair.
Old Jun 29, 2012 | 08:00 AM
Aaaccckkkk! Tony
Dont worry its just mocked up!
Oh cool! Brian, what do they look like/where can i find them??
I really just need a little bit of movement and i think it will be perfect.
Old Apr 5, 2013 | 08:57 PM
rcrac3r's Avatar
Originally Posted by Tony72Cutlass'S'
Dear All,
I'm looking for this same pulley. Allan do you have one? PM if you do please.
Old Jan 3, 2026 | 08:50 AM
nj_cutlass72's Avatar
see below
ok Im doing time travel w this post…is this diagram for 1972, bottom is cutoff, thanks if it can be verified 😎
Old Jan 3, 2026 | 02:45 PM
cdrod's Avatar
Rodney
1972 Cutlass Pulley Diagrams
Here are the pages your looking for.
Rodney
Old Jan 3, 2026 | 04:41 PM
Rodney
thanks Rodney
Old Jan 4, 2026 | 07:37 AM
Instead of a new thread,ill ask here, im looking for the single groove water pump pulley PN 391113
Old Jan 4, 2026 | 07:51 AM
11971four4two's Avatar
MOTORHEAD
Originally Posted by tony72cutlass's'
dear all,
got a great looking powercoated pulley from mike. The pulleys line up real close. All i might need is a washer or two under the lip and it should be perfect.
what do you guys think?
mix match 2 groove crank pulley 3 groove water pump
bronze66f85
Mar 21, 2022 11:57 AM
yeahbuddy
Mar 11, 2022 04:18 AM
Ral
Mar 1, 2022 01:34 PM
Octania
Sep 24, 2013 05:42 PM
Terryc
Jul 26, 2012 07:02 PM
