1970 Ring & Pinion, 8.6 rear end
I am looking for a nice used 3.42 ring & pinion gear for a 1970 Oldsmobile 12 bolt/10 bolt internal bolt pattern rear end. Only a 3.91 and aa 3.42 will fit, I have the 3.91 am looking for the 3.42 set. Reply here or write me at director@hurstolds.com.
Good advise. I am restoring the car and it will just be driven to local car shows. I am trying to get a better highway gear to drive to those shows. There are many 10 bolts available for cheap but still want the 12 bolt look from behind. Sometimes i wish I loved Camaro's instead!
What?
What? If the rear end is set up properly the gears won't wear any faster than a new set. If the wear pattern on the used crown and pinion is good you'll be fine with a used set.
use randys ring and pinion. great guys, they made new posi for my 12 o.they use a ford 8.8 posi 28 spline cut to fit olds housing. have to use richmond gears. they can hook you up. have done 4 rearend builds with their stuff. yukon posi units.
Fyi
As discussed with you weeks ago in a PM you will need both the gear set and the carrier if you choose a gear below 3.42. Good luck.
1970 8.6 rear end
I shipped a complete rear to Wyoming about 5 years ago with Fastenal. Email me to discuss: drolds1@bellsouth.net. Thanks, Bob.
67442nut
January 6th, 2017 09:09 AM
oldspackrat
August 10th, 2014 10:03 PM
