1970 Oldsmobile Delta 88 brake parts
Old Feb 26, 2016 | 09:28 AM
Aeslehc71's Avatar
I'm in need of Brake Rotor for '70 Olds Delta 88!! Any help would be greatly appreciated!! Having trouble locating on for front Thanks...
Old Feb 26, 2016 | 09:33 AM
Aeslehc71's Avatar
'70 Olds Delta 88 Front Brake Rotor
ISO front brake rotor to fit my 1970 Oldsmobile Delta 88. Thanks!!
I merged your 2 threads as they both relate to brake parts. Have you tried your local parts store? Also online, Rockauto is a good source for parts.
Old Feb 26, 2016 | 09:55 AM
Aeslehc71's Avatar
Rotor
Yes I have. Ok, thanks..
Old Feb 26, 2016 | 12:50 PM
2blu442's Avatar
I believe these are no longer available GM new or aftermarket. I think you'll have to locate one from a parts car. I've got a parts car with disc brakes but I'd like to keep everything together and sell it as a set someone could use to swap discs onto a drum brake car.
John
Old Feb 26, 2016 | 01:09 PM
Your right, the rotors are not available. The power booster is. Sorry, my post was made prior to merging the 2 threads and I did double check the booster. This may be something to look at for the rotors.
https://classicoldsmobile.com/forums...sc-brakes.html
Old Feb 27, 2016 | 12:17 AM
65B01Delta's Avatar
eBay item number: 151797382919
69-70 Oldsmobile Delta 88 / 98 Brake Disc / Rotor- PAIR
Old Feb 28, 2016 | 03:31 AM
Aeslehc71's Avatar
eBay listing...
Thanks, that would have been nice,..but listing there ended, I'll continue looking, appreciate the help
Old Feb 28, 2016 | 07:39 AM
65B01Delta's Avatar
I knew that when I posted here.. Yes, They did not sell, so just send the seller an email through eBay, I'm sure he'll reply to you.. I do it all the time...
Old Feb 28, 2016 | 09:00 AM
Octania's Avatar
"This auction is for a pair of replacement front brake disc rotors for a 1969-1970 Oldsmobile Delta 88 or 98. These have been unavailable since the mid 90s. We are offering a reproduction of the original disc portion of the rotor. They are CNC machined from a dealer-quality brake rotor blank, with the best casting available. This is an exact replacement for the delta 88 and 98. No modifications are necessary. The hub portion of your old rotor needs to be separated and re-used. Fortunately, it does not wear, and is typically very corrosion resistant. It's a little difficult to see, but the original brake rotor on these cars is a two-piece assembly that can easily be disassembled using either a shop press, or a block of wood and a hammer. You simply set the rotor flat on its disc and press the wheel studs straight down, or lay a piece of wood on top of each stud and pound it down with a hammer. Once the studs fall out, the disc separates from the hub with relative ease. The only difference between this and the factory rotor is the 10 bolt holes (the original had 5), but these are completely invisible once the hub is installed. Please email me if you have any questions before bidding. Free US shipping, email me for other locations. Thanks!"
I think those wheel studs are peened in place and "should" be cut out with an annular cutter per CSM procedure.
It looks like someone finally took the initiative to find a similar part and have it machined to suit. Good for them. Send an inquiry. Often times, if they can sell to you NOT thru the high priced selling venue, you get quite a savings. I know I have to add almost $200 to the price of an intake to make selling it thru the E vendor a bearable experience.
I have a used pair, but no one wants a used pair, right? They might not even be usable. Hours of work just to find out. Might as well get the new ones.
Maybe someone should buy the dead ones and the new rotors and transfer using the proper tooling so that the wheel studs stay in like they should. Then offer the package, ready to install.
Old Feb 28, 2016 | 09:10 AM
True, but good luck finding the correct annular cutter. On my 62, I simply pushed the studs out with my press and had to buy studs with oversize knurls to fit tightly in the newly-enlarged holes. Not the end of the world, but just be aware of it.
Old Feb 29, 2016 | 12:34 PM
mpolds's Avatar
And that "10 bolt" repop/reject is trouble....
Somewhere on this forum is the thread indicating that I have 2 remaining N.O.S. Rotors --- with no cutting, no slicing, no dicing, etc., etc.
George Rodriguez googled it -- and was sending me a postal money order for them 15 days ago "IMMEDIATELY" according to him -- and I haven't received any money --and he has his phone on "messages full" mode -- so
he doesn't want to indicate to me he has no money....
So, I have EXACTLY 2 N.O.S. KELSEY - HAYES available.....
You are welcome to call me -- Craig -- 516 - 485 - 1935 ... New York...
Old Feb 29, 2016 | 04:22 PM
Danny Bingaman's Avatar
70 Oldsmobile Disc brake rotors
I have a 70 Olds 98 which have the Disc brakes on it and which I like to sell as complete set . But will sell as RH or LH contac me at d.rocwal@hotmail.com AUTO PARTS ,for more information . Also have many parts for 68-70 Olds 98-88 , some Cutlass , 78 cutlass Brougham,63-64 Buick's, 65 F-85 4 door sedan , 79 F-250 Supercab , . You can text me but no calls for I'm tone deaf . 207-852-9729 .
rocwal
Dan B
Kilmster
Brakes/Hydraulic Systems
Aug 6, 2014 05:41 PM
bgarrett
Feb 25, 2012 11:49 AM
JohnNC
Jan 4, 2012 01:39 AM
EightballZ
Sep 28, 2010 01:45 AM
65Delta88
Nov 5, 2008 09:30 AM
