1970 floor shift steering column
Old Feb 23, 2011 | 02:50 AM
g77rvd's Avatar
Looking for a 1970 cutlass floor shift steering column
or any recomendations on where to get a quality rebuilt one?
Old Feb 23, 2011 | 06:18 AM
507OLDS's Avatar
I sell them restored for $125.00 plus the shipping.I just finished/sold 3 of them,and I have a few more apart.I can do satin black,or other colors,if needed.
Old Feb 23, 2011 | 09:33 AM
Al Godon's Avatar
Do they have the correct 70 ignition switch?
Old Feb 23, 2011 | 09:53 AM
g77rvd's Avatar
Think ill take one, how much with shipping to 78232? Does it come with everything, or what do I need in addition to successfully install? that harness is working out great BTW should put new dash on this weekend and be done with that job
Old Feb 23, 2011 | 10:24 AM
507OLDS's Avatar
It comes without the key/cylinder,so you can install your own.
You will need to reuse your key/cylinder,and your turn signal lever.
The ignition switch,and the lower switch is included.The lower switches are different depending on year,and if it's an auto or 4-spd.Just specify what you have,and I'll put the correct one on.
Old Feb 23, 2011 | 10:34 AM
g77rvd's Avatar
Yeah my column lock plate is stuck on shaft think the hub may have been pressed in too far, but all that is included right? You want my core when I'm done with putting rebuilt one in?
Old Feb 23, 2011 | 11:23 AM
507OLDS's Avatar
There is a small clip ring that holds that lock plate on.They make a tool the pushes the lockplate down,so you can get the clip ring out.then it all comes apart.
Old Feb 23, 2011 | 01:36 PM
g77rvd's Avatar
I know I removed the lock ring, lock plate doesn't move, it gets stuck on shaft, even with light prying when I look closely the tapered shaft seems damaged, flared out if you will preventing lock plate from moving.
Old Feb 24, 2011 | 12:03 AM
svnt442's Avatar
Brian did you get the box I sent you?
Old Feb 24, 2011 | 05:08 AM
507OLDS's Avatar
If you want,ship your column up to me,and I'll see if I can get it apart.I just didn't want to sell you something if you don't really need it.
Randy,
Yes,I got your box.Now I've got some more spare parts.
shamusj
Apr 27, 2021 05:45 AM
hvysupreme
Feb 18, 2017 12:40 PM
Rocketbrian
Oct 2, 2013 10:18 AM
Bitburger
Dec 30, 2012 04:49 PM
Alocatelli
Dec 10, 2012 07:49 AM
