1970 Emissions connector, end of the snorkel
Old Jan 2, 2019 | 04:28 PM
BSiegPaint's Avatar
Does anyone still have one of these little hose connectors that fit into the hole at the end of a 1970 air cleaner? My plan is to 3D print one if I can get a good look at or measurements off one. I have already designed a piece that will work, but it would be nice to get it close to correct, if possible. Any pics from any and all angles would help!!
Old Jan 2, 2019 | 04:31 PM
classicmuscle442's Avatar
Need one two, interested to see an original. Is this a California only item for '70?
Old Jan 2, 2019 | 11:02 PM
shiftbyear's Avatar
My 70 W-30 had the nipple, got lost over the years. Found another one on a 2bbl air cleaner. I'm curious if all 1970 charcoal vapor canisters are 3 port or just the Ca models. There are numbers on each piece, the nipple is plastic. Good luck.
Old Jan 3, 2019 | 04:20 AM
BSiegPaint's Avatar
Awesome picture, thank you! I am under the impression that all '70's had the 3 port canisters, if they had one at all.
Old Jan 3, 2019 | 06:46 AM
My '70 has the three port canister but it is a Ca. car.Would be interested in purchasing this fitting if anyone has or knows where to purchase.
Old Jan 3, 2019 | 09:12 AM
VC455's Avatar
Barely Registered
The Vapor Control Canister was a mandatory option for vehicles delivered in California. An option for the canister did not appear on the Wholesale Car Order Form; therefore, no one could order the canister on a car being delivered outside California.
The 1970 canisters have three-port tops.
I'm interested in getting the air cleaner connector as well.
Old Jan 3, 2019 | 09:17 AM
BSiegPaint's Avatar
Based on the picture above, and knowing the size of the hole in the air cleaner, I submitted a drawing with estimated measurements to a friend who has a 3D printer. If anything comes from it, I'll sure let you all know. The clip doesn't seem to be a standard one that I can find - if anyone has an idea for that, let me know. Brake line clips are almost all 1/2", and that is too big for this piece. This looks to require about 3/8" on the inside. I found a usable clip on eBay that I'm going to try, but it would be nice to find something better.
Old Jan 3, 2019 | 09:37 AM
BSiegPaint's Avatar
I found a GM crankcase connector 1255-0625 that was used on the early 90's LT1 engines and ordered it. I have no idea if the size is correct yet, but it was the closest thing I could find for now. It might be an alternative if nothing else works...
Old Jan 3, 2019 | 02:33 PM
Clip can be found, Dorman probably has something similar, will do some searching.
Old Jan 4, 2019 | 05:20 PM
mobileW-30's Avatar
1970 Emission connector
Count me in on the part you make for the NA9 system . The other part that is needed the TEE # 405130 if you no of or have one I will take it .
Old Jan 5, 2019 | 11:42 AM
BSiegPaint's Avatar
i know the part you’re looking for - only on the W-30, I believe. The 350 cars like mine just had a regular tee fitting into the PCV line. Not sure why they made the W-30 so complicated there...
Old Jan 5, 2019 | 02:31 PM
anthonyP's Avatar
Not to change the subject, but has anyone drilled or stamped out the hole in the snorkel? Need to make the emission fitting hole in a reproduction OAI air cleaner base without distorting the snorkel. Not a California car, but a '70 Rallye so needs the hole in the snorkel.
Old Jan 5, 2019 | 05:48 PM
No tee on Ca. w30 car, goes from canister to air cleaner snorkel.
Old Jan 5, 2019 | 07:57 PM
BSiegPaint's Avatar
i think he’s referring to the tee that comes off the carb on the PCV hose. Weird little piece that other cars don’t have.
Old Jan 6, 2019 | 09:47 AM
mobileW-30's Avatar
1970 Emissions Connector , end of snorkel
yes that is correct that tee came on all 1970 CA 4 speed cars . saw one at pick & pull Santa Fa springs it was a 4 speed 442 back 1980 but it crumbled in my hands .
Old Jan 6, 2019 | 01:49 PM
Interesting never saw one with a tee in PCV line.
70sx455
Jun 17, 2019 06:02 AM
BeenThere
Mar 1, 2017 02:18 PM
BeenThere
Jan 21, 2017 07:35 AM
tdhill01
Jan 27, 2016 11:41 AM
dk-52
Aug 20, 2010 05:52 AM
