1969 Hurst Olds
Old Nov 14, 2021 | 05:42 PM
alsmith787's Avatar
1969 Hurst Olds
Looking for 1969 olds 442 rear speaker 10 ohm; -
also rear window defogger w/wiring completeThanksAlsmith787
Old Nov 14, 2021 | 06:19 PM
69442murph's Avatar
I have a complete defroster unit, with wiring, etc but wll need to test the fan to make sure it works. Removed from a 69
pm a email or text number I can send pics to tomorrow if interested. thanks
tim
Old Nov 14, 2021 | 07:35 PM
alsmith787's Avatar
1969 h/o
Thanks Tim, yes I'm interested in the Complete defogger + wiring + grill & I assume dash switchby wiring is that the full wiring from the dash to the rear tray, again thanks for the replyEmail me at (alsmith787@msn.com)
Old Nov 14, 2021 | 07:39 PM
10 Ohm. Is that real?
Old Nov 14, 2021 | 07:45 PM
alsmith787's Avatar
Rear speaker 6"x9" 10 ohm
Yes that's real the radio that year was a am/fm MONO ---- stereo wasn't available on A-body cars that year --- & you always run the risk of blow the ballast resistor in the radio with any ohm value different odd as it might sound + the radio doesn't drive the speaker enough to sound clear
Old Nov 14, 2021 | 07:51 PM
Wouldn't that be the output transistor and not a ballast resistor?
Old Nov 14, 2021 | 08:02 PM
alsmith787's Avatar
Yup your right I forgot I always see more internal damage then just the output resistor but that is the one that fails first sometimes it's the only thing that fail unfortunately for me a number of years ago on different A-body cars I always found more damage -- just lucky it guess lolBut I'm still looking for a rear speaker 10 ohm do if any of you out there have one I'm interestedThanksalsmith787
Old Nov 14, 2021 | 09:29 PM
I always thought that was an eight ohm not ten.
Old Nov 15, 2021 | 05:09 AM
alsmith787's Avatar
Rear Speaker 69 H/O
So did I growing up I always remember all speakers in those years being 8 ohm but believe or not Delco remi made provision for a range of 8-10 it's in some of their manuals & I've seen quite a few oem speakers that had 10 ohm stamped on baseAGAIN IF ANY OF OUR CHAT BUDDIES HAS a Rear Speaker in that era 6"x9" 10 ohm I'M VERY MUCH INTERESTED IN PURCHASING
THANKSalsmith787
Old Nov 15, 2021 | 05:19 AM
BeenThere's Avatar
What is the part number of the speaker you need?
Old Nov 15, 2021 | 05:38 AM
alsmith787's Avatar
Rear Speaker 69 H/O
THANKSalsmith787
If you need a part # it's GM#7302013 BUT! that isn't the only part that works the rear speaker is the Same in A-Body 68 - 69 - 70 - 71 & some 72's also Buick Skylark rear speaker those same years are compatible
Old Nov 15, 2021 | 05:53 AM
69 Hurst's Avatar
Olds Fanatic
Bought mine from OPGI, part #S240839 for $33.99. Sounds great. Be sure not to use anything but a 10 ohm.
Old Nov 15, 2021 | 07:16 AM
BeenThere's Avatar
Rear speaker
I believe this is the typical 1968-1972 Olds "A" body rear spaeker. Delco, 6 X 9 size, shallow dish, 10 OHM. This one is dated 1969, but I don't remember what car this one came from. It has been reconed and works fine. $115.00, includes safe insured 48 state shipping. PM me if interested.
Old Nov 15, 2021 | 07:18 AM
BeenThere's Avatar
Pictures
Old Nov 15, 2021 | 07:25 AM
alsmith787's Avatar
Speaker
Been There thanks do you remember if there was a wattage on that speaker --- just checking
Old Nov 15, 2021 | 08:51 PM
Boy that sounds like a good deal.
WTony
Jan 15, 2020 06:51 AM
ericjimmysfla
May 22, 2015 07:50 AM
Funkwagon455
Aug 28, 2014 09:22 PM
Hairy Olds
Jan 2, 2014 03:56 PM
wizarddrummer
May 4, 2011 09:55 AM
