1968 Hood Hinge Springs
Old Jul 6, 2016 | 11:11 AM
Stevec's Avatar
Does anyone make new hood hinge springs for a 1968 442 or do I need to find a clean set of originals?
Old Jul 7, 2016 | 12:31 PM
rjohnson442's Avatar
Mr. Johnson
They make new repops from all the major suppliers, springs too.
Old Jul 7, 2016 | 12:59 PM
Stevec's Avatar
Thank you!
Old Jul 7, 2016 | 01:44 PM
I moved your post to parts wanted, I don't think 68 is that easy to find. All the other years yes, good luck.
Summit references this Goodmark pn, but Goodmark doesn't reference your model for the same pn. Fusick or any of the the repro places do not reference a 68 part.
https://www.summitracing.com/parts/g.../model/cutlass
Old Jul 7, 2016 | 06:48 PM
Stevec's Avatar
Thanks old cutlass! much appreciated!
Old Jul 9, 2016 | 04:51 AM
allyolds68's Avatar
Are you sure it's the springs? More often than not the hinge pivot points are rusted and the hood doesn't close properly.
Old Jul 9, 2016 | 12:39 PM
Stevec's Avatar
Ally the pivot points look ok. The driver side of the hood is raised but you can push it down. It looks as if the left front fender needs to be raised but it's actually the hood that needs to come down.
Old Jul 9, 2016 | 12:45 PM
It may be an adjustment issue. Have you tried to adjust the hinge mounts to the fender. I think the CSM has a section on it.
Old Jul 9, 2016 | 12:58 PM
allyolds68's Avatar
X2. Try lowering the front of the hinge or raising the rear. I know intuitively that seems wrong but that's the adjustment that's usually needed.
Old Jul 9, 2016 | 02:01 PM
Stevec's Avatar
Ok guys! Thanks for the advice!
Old Jul 11, 2016 | 08:45 AM
1968_Post's Avatar
Are the factory hood spacers in place? 2 small discs at the rear bolt to the hood.
Old Jul 11, 2016 | 03:22 PM
Stevec's Avatar
Yes they are. The hing is bad.
RetroRanger
Nov 11, 2024 09:45 AM
70Post
Dec 28, 2014 02:24 PM
ostie13
May 29, 2014 10:31 AM
Oseeker13
Sep 19, 2013 06:29 PM
sammy
Nov 25, 2012 04:14 PM
