1967 Oldsmobile 400CI
Old Jul 25, 2024 | 01:15 PM
Lykinsj's Avatar
I am looking for a full set of ORIGINAL .921 lifters that came out of a 67 E block. I have searched far and wide for lifters that won’t spew oil out of the top and I have been told the valve and metering of remade lifters do not work for these engines. If anyone has a set of originals please let me know.
Old Jul 25, 2024 | 01:53 PM
For clarification, do you want good lifters to use in the engine, or do you want used lifters to salvage the internal parts?
Old Jul 30, 2024 | 07:29 PM
jmcghee's Avatar
I believe Mark Remmel know as cutlassefi on this forum, can source them for you .
Old Jul 31, 2024 | 06:21 AM
BSiegPaint's Avatar
Please take a look at post #82 in this thread
​​​​​​https://classicoldsmobile.com/forums...3/#post1581985
If these could possibly be what you're looking for, they have just been refinished by Egge and I would make you a good deal on them. Note I have 14 that might be what you want, and 2 that are different. Mark can set you up with a new set (that's what I just bought), but they are quite expensive fyi.
Old Jul 31, 2024 | 02:06 PM
Andy's Avatar
Johnson hylift sells 921 lifters, made in USA. They are the best in the industry
Old Jul 31, 2024 | 02:29 PM
Oldsmaniac's Avatar
Years ago got a set from EGGE and they were fine. Then heard the ones they sold had the excessive oil issue. Got a set from Johnson and they are fine. I would think by now any company selling these lifters would be aware of the oil issue? One would think...
Old Aug 3, 2024 | 07:07 AM
68442's Avatar
OK Here is my 2 cents, I did a rebuild of one of my 67 400's about a year or two ago and used the Johnson lifters(Purchased directly from them no middleman). I had an oiling problem unrelated to the lifters but in the course of figuring that out i noticed a s#$t load of oil going up to the rockers. Contacted Johnson spoke at length with them more than a few times. They were unconcerned and could not have cared less. And then they just ignored me. They were not interested in solving the problem or even open to recognize a possible problem. I then put restricted pushrods in and that got things under control. I was not burning oil or any other ill effects form it to start, had i not been searching for a oil psi problem possibly i would not have noticed it. Did another build/refresh on another 400 motor kept the Factory OEM cam and lifters. Normal expected flow from them. Thats my experience take it for what its worth.
Old Aug 3, 2024 | 07:28 AM
Andy's Avatar
‘were they Johnson lifters or Johnson hylift? Both make lifters
Old Aug 3, 2024 | 10:01 AM
Oldsmaniac's Avatar
My last build was with J Hy lift, have no idea what is taking place under the valve covers, no issues so far...
Old Aug 3, 2024 | 12:34 PM
68442's Avatar
Hylift Johnson.
Old Aug 3, 2024 | 12:37 PM
68442's Avatar
Like i said if it were not for me addressing a different issue i'm not sure if i would have know either.
Old Sep 4, 2024 | 09:45 AM
lemoldsnut's Avatar
E block .931 lifters
I have a set of used originals
Contact me direct lemoldsnut@aol.com or 541-815-4363
67 E .921 lifters
Old Sep 14, 2024 | 09:10 AM
Oldsman59's Avatar
Contact John at Rocket Racing. I just bought a set from him last year and have had no problems.
Lykinsj
Jul 24, 2024 12:44 PM
1967442
Jan 22, 2024 09:35 AM
442Harv
Jun 2, 2021 09:32 AM
Big Todd
Aug 1, 2010 10:04 PM
Hairy Olds
Dec 23, 2009 08:48 AM
