1967 cutlass convertible window sill moldings
Old Apr 4, 2020 | 01:51 PM
Rocket Olds's Avatar
looking to purchase both sides window sill moldings for both front and rear windows for my 67 cutlass convertible
Old Apr 5, 2020 | 10:23 AM
rocketscientis's Avatar
67 sills
Do you have picture of items needed ?
I am currently searchin th vertical chrome pieces that hold weatherstrip between side windows in no - pit condition & believe I either have what you need ..
Or find it whenever i hunt my stuff..
If you cant load pix here , get over it ...I'm tryin to...load & get over it..
Put men on moon
..but no olds picture transfers...
Currently looking into reproducing 67 supreme rear 1/4 potmetal trim pieces..in America by car people...so they fit & look good....wondering if anyone else would be interested in such things ?
Old Apr 5, 2020 | 11:56 AM
lemoldsnut's Avatar
No body makes those rear quarter trim pieces that I have found. Be it Chinese or American. I have many and often the studs are rotted off. Very common problem.
If the ones I have pictured are the moldings the OP is looking for these are stainless on a convertible and Aluminum on a hardtop. The rear ones on a convertible are convertible only and the pinch weld molding is unigue to these as well as they joint together. These are the ones on my 67 442 Converible.
Larry
lemoldsnut@aol.com
Old Apr 5, 2020 | 12:03 PM
Larry those are the ones I am looking for.
Old Apr 5, 2020 | 12:32 PM
Considderd B-85 ?
Hav pair conv doors
will look n c
Old Apr 6, 2020 | 12:07 PM
oldtruck lover's Avatar
These are known as the B85 option. Stainless for convertible, aluminum for the coupe. I have both coupe and convertible with this option. I was lucky to find these for my 66 convertible on e bay last fall. Note that two long pieces that go around back of the rear window are also different with the b85 option. They are open on the ends where they insert into the shorter curved pieces that fit along the bottom of the quarter windows. These pieces have closed ends on the non b85 cars. There were two of these long pieces on ebay yesterday. they were listed as fitting pontiac olds and buick convertables. I do not know if that is true, good luck
Old Apr 6, 2020 | 12:10 PM
Are the pinch weld moldings different for the b85 option? I am aware that the fuzzies are different as they do not have the stainless bead along the top edge.
Old Apr 6, 2020 | 06:36 PM
i have been looking on ebay and cant find. I tried window sill moldings, door sill molding, belt moldings,window trim and no luck. what verbage did you use to locate
Old Apr 7, 2020 | 07:59 AM
lemoldsnut's Avatar
Reveal moldings are a common name for them too. TO BE VERY CLEAR. THE ENTIRE SET OF REVEAL MOLDINGS OR WHAT EVER YOU WANT TO CALL THEM IS UNIQUE TO CONVERTIBLE. IT REQUIRES THE SPECIFIC PINCH WELD MOLDING AND THE QUARTER AND DOOR SECTIONS. ALL ARE CONVERTIBLE ONLY. EVEN ON THE DOORS AS THEY ARE STAINLESS NOT ALUMINUM LIKE ON A HARDTOP.
The picture shown is the ones on my car. You can see on the quarter molding it goes into the pinch weld molding. That is why the pinch weld molding is different. Hope this clears this up.
Larry
Old Apr 7, 2020 | 09:19 AM
Still there. Ebay.com/itm/1966-1967 GTO GS 442 convertible top rear moldings used. Chicago muscle cars is the vendor. Note that the molding for the convertible has a hold on each end where it connects to the piece along the quarter window. This end screws to the body and is covered by the quarter molding.
I do not know if GTO GS and 442 are the same.
Good luck.
Old Apr 7, 2020 | 06:29 PM
i found them, thanks. I see now that this project will take some time and money. Thanks to all, again Mike
goldie442
Aug 13, 2018 10:17 AM
NotDads442
Jul 18, 2018 06:55 AM
dadedave
Aug 4, 2013 04:16 AM
Oldsguy
Jul 23, 2008 07:44 AM
beach-boy60
Mar 17, 2008 01:41 PM
