1971 455 4 speed short block
Old Jul 18, 2014 | 07:21 AM
70sx455's Avatar
Short block complete runs, bored .030 cast pistons, does not smoke, no noise. Just removed from car 1 month ago, had a 70 455 rebuilt. Motor had low oil pressure at idle, so it will need a oil pump, that is why I took it out. Other than that it ran great $600.
Old Jul 20, 2014 | 08:29 AM
anthonyP's Avatar
Hello. Do you know if the engine has a factory drilled crank for the manual trans, or if it was drilled afterwards? Are the current pistons equivalent to the factory '71 low compression pistons? What heads were on the engine? Thanks, Anthony
Old Jul 20, 2014 | 09:36 AM
70sx455's Avatar
It is a factory drilled crank. Pistons are same dish as a stock 1971. I bought motor w/ C heads, I put my B heads on it and drove it.
Old Sep 16, 2014 | 12:23 PM
70sx455's Avatar
Still for sale
Old Sep 17, 2014 | 06:05 AM
limegreen71w30's Avatar
Any chance this is a nodular or better yet a forged crank? I assume stock rods. Has the crank been ground do you know? Thanks
Ed
Old Sep 17, 2014 | 07:16 AM
anthonyP's Avatar
Message sent.
Old Oct 14, 2014 | 12:30 PM
70sx455's Avatar
New Lower price $550
Old Nov 12, 2014 | 07:37 AM
jstohlman's Avatar
any chance there is a vin# stamped on the block,,searching for the block out of my 71 W-30 4 speed,,came out somewhere in Michigan or Pa ,,, I know it is a shot in the dark but what the hec last 6
of my vin are 143046,, thanks ,, Jim Stohlman
MyPaceCar
Jun 15, 2014 07:43 PM
dnmfranco
Oct 27, 2013 07:49 PM
smietana
Apr 13, 2011 12:08 PM
bubbasz1
Jun 6, 2010 01:33 PM
