68-72 rolling A-BODY FRAME ( OHIO ) $800
Old Jan 20, 2014 | 11:09 AM
ohiocutlassparts's Avatar
Yes i have a nice a-body rolling frame new drum brakes on front has a 1970 olds cutlass 12 bolt open rearend..frame is from a pontiac...asking $800.. Alum wheel are extra..body bushing holes are in good shape..has some new front end supspension parts sorry no rear springs....call or text 937-689-0914 dayton ohio FRAME WILL FIT 68-72 OLDS CUTLASS BUICK CHEVELLE GTO 2 DOOR ONLY HARD TOP
Old Jan 20, 2014 | 01:45 PM
tru-blue 442's Avatar
Old School Olds
Should be the same frame as the
post cars as well, yes?
Old Jan 20, 2014 | 05:41 PM
frame
post I think so
Old Jan 21, 2014 | 11:11 AM
507OLDS's Avatar
That is a 1968 frame,for anyone that is picky. Hardtop and post coupe are the same.
Old Jan 21, 2014 | 11:36 AM
ent72olds's Avatar
Registered Luser
Brian, what tips you off to the year of the frame?
Old Jan 21, 2014 | 01:08 PM
507OLDS's Avatar
The extension on the engine crossmember is 68 only. The axle crossmember and rear rails are 68-69 style. However,this will fit/function under any 68-72.
Old Jan 22, 2014 | 09:59 AM
69442C's Avatar
I've restored a couple of 69 442's and had a few 69 Cutlass parts cars and all had the extension on the front engine crossmember. The most recent one was an 02A build date car.
Old Jan 22, 2014 | 07:23 PM
507OLDS's Avatar
Maybe some early 69's had them. I have only seen them on 68's. I am referring to the small plate that is welded on separately,like a skid plate. The other frames just have the shaped crossmember.
Old Jan 22, 2014 | 07:59 PM
ent72olds's Avatar
Registered Luser
Good info! Thanks!
Old Jan 22, 2014 | 08:09 PM
Paladin31's Avatar
Framed
Here's a aug 69 built frame for comparison.
Old Jan 23, 2014 | 03:56 AM
507OLDS's Avatar
See how that is different in the front? The one that Paladin pictured is the same shape as 70-72. The 68's have a separate plate that is welded,and that area is also shaped slightly different.
Old Jan 23, 2014 | 07:56 AM
69442C's Avatar
Good info and I didn't realize 68 was done different than the other years.
ohiocutlassparts
Jan 18, 2014 07:51 PM
507OLDS
Apr 20, 2011 05:55 AM
1969goatman
Aug 30, 2010 07:44 PM
Alb
Dec 11, 2009 06:29 AM
