Olds Big Block 400 & 455 Blocks
Old Nov 14, 2013 | 04:47 PM
mccparts's Avatar
Selling the blocks I have left. 1- Fa 455 block baked blasted and pressure checked. Over 250 in work done. Standard bore. $300 guaranteed good. 1- 69 455 F block $200. 1 69 442 400 G block. standard bore. Baked blasted and pressure checked. Guaranteed good $750. 1- 66-67 400 E block with forged steel crank standard bore $675. 1-69 400 G shortblock. Missing 1 rod/piston. Standard bore $675. 1 set C heads $250 bare. 262-527-5279
Old Nov 15, 2013 | 08:48 AM
cdoering's Avatar
Whats the julian date on the 455 and what is the vin number on the block
Old Nov 15, 2013 | 10:07 AM
rjohnson442's Avatar
Mr. Johnson
Location?
Old Nov 15, 2013 | 10:29 AM
cdoering's Avatar
[QUOTE=rjohnson442;615468]Location?[/QUOTE
The Julian date is where the distributor goes. There will be a number there (1-365). The vin number is stamped on the block below the #1 piston. Hopefully it starts with M30 followed by 6 digits.
Old Nov 15, 2013 | 11:06 AM
stlbluesbrother's Avatar
[QUOTE=cdoering;615477]
Originally Posted by rjohnson442
Location?[/QUOTE
I think rjohnson442 is asking the physical location of the engine blocks. And, by the looks of the area code in the seller's phone number, it's likely they are in the Milwaukee, WI area.
Old Nov 15, 2013 | 04:05 PM
mccparts's Avatar
You are correct Mr. Johnson. I live in Port Washington, WI about 20 minutes directly north of downtown Milwaukee, right off of I43. As for the 455 block date code, which block are you referring to? the Fa block or the 69 F block?
Old Nov 18, 2013 | 05:31 AM
Mr. Johnson
Thanks a little far for me though.
Old Nov 18, 2013 | 02:14 PM
mccparts's Avatar
Julien date code for the 69 F block 455 is 326
Old Nov 18, 2013 | 02:16 PM
mccparts's Avatar
VIN #is 39M201847
Old Jan 22, 2014 | 04:59 AM
Dave Leonard's Avatar
Do you ve any idea of what shipping would be to FL?
Old Jan 22, 2014 | 09:23 AM
berettass's Avatar
What's the vin number for the 69 400?
Old Jan 22, 2014 | 04:52 PM
I am intrested in the 66-67 400 you have. Is it still the stock 4" bore and what do the cylinders and crank looik like?
Last edited by Dave Leonard; Jan 22, 2014 at 04:56 PM. Reason: can call me at 352-685-6213 anytime
Old Aug 21, 2014 | 05:45 AM
400 block and crank
Would you sell just the crank and if so what would you want for it?
Old Aug 21, 2014 | 05:46 AM
Would you sell just the crank and how much?
Old Aug 21, 2014 | 03:02 PM
Bernhard's Avatar
This is a post from 2013
70442rag
Dec 30, 2014 09:41 PM
TicTocTach
Feb 19, 2013 05:16 PM
69442
Sep 8, 2012 05:23 AM
fast67vellen2o
Aug 12, 2012 06:53 PM
antweave
Apr 22, 2011 11:32 PM
