need to finsh the 66 lets get rid of some stuff
Old May 27, 2008 | 10:10 PM
gearheads78's Avatar
car guy
In the last couple years I have parted out a 64 Chevelle 4 door A/C car, 66 Lemans , 67 442 Convertible and 72 Cutlass S. I still have misc parts for each of thos cars so if you need anything let me know. I also currently have a 84 Dealta with 307/2004r that will go to the scales when I get the chance.
Here are some more parts I have laying around taking up space
425 block bored .030 over was assembled as a short block but never fired. not sure if its a 39 or 45 motor Light corrosion in the clys. Also has ARP main bolts 100.00 plust freight
425 auto crank 10/20 one rod journal nicked and will need polished. Was fresh ground and sitting in the block above. 135.00 shipped
SOLD
425 .030 shallow dish forged pistons with stock rods and ARP rod bolts. Were installed but never fired. Two different part # pistons but they are the same piston with superceeded part # $120.00 shipped
PENDING
BBO torker intake someone cleaned up the outside lettering but does not look to be cut on the ports 145.00 shipped
PENDING
new valves were in an unmarked Pep box not sure it that the brand or not
one set is 2.070 4.695 long with p3189-HPC marking
other is 1.630 4.700 long marked p2498-HPC
either set 80.00 shipped
350 / 455 Olds flywheel might need a resurface of might clean right up 65.00 shipped
PENDING
Old style tall skinny NOS bottle with high flow valve and -4 nipple includded 65.00 shipped
PENDING
Carb Shop 920 custom carb was on a SBC nitrous street car running 6.20's has been sitting on my shelf for several years so I would assume its needs kitted. $275.00 shipped
SOLD
Used line lock was working when pulled several years ago. 20.00 shipped
new Autometer 3313 fuel pressure gauge with isolator 2 1/8" 110.00 shipped
new installed but never fired Moroso SBC pan #20191 170.00 shipped
mr gagasket 5903 header gaskets SBC Bodix D-ports 14.00 shipped
NX bottle heater slightly used no switches or gauges 100.00 shipped
new Wilwood proportioning valve 35.00 shipped
3" Exhaust system with Dr gas xpipe and big case big block series flomasters. They were what was recommented to me about 6 years ago for a 600 HP street car. Were only on a car about 3000 miles. The muffers alone were 140.00 each back then. Is set up for a G-body that had the rear seat wells beat in a little. Will cut wher you want for shipping or just send the muffers. 250.00 shipped for all of it will at least need to be cut in 1/2 for shipping SOLD
2 early 350 olds motors with 7A heads on both 1 is 2 brl and the other is 4 brl all or parts make offer
If it says shipped that means I am including freight to a commercial address includded in that price. If is a heavy item add 5.00 for residential or 2.50 for the lighter stuff
Old May 27, 2008 | 10:31 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
PM sent on the rotmasters.
Old May 28, 2008 | 07:33 AM
2blu442's Avatar
Parts
Email sent on the 425 pistons and 455 flywheel. John
Old May 28, 2008 | 08:38 AM
car guy
Pistons are spoken for many times over (must of had them too cheap) I have 1 person in front of you on the flywheel so you are first alternate. I can't see my email from work so if you have questions you can PM me here.
Olds462
May 6, 2012 06:54 AM
MDchanic
May 1, 2012 12:58 PM
MrLightning
Aug 28, 2011 12:22 PM
John Prest
Dec 13, 2009 08:50 AM
Nilsson
Sep 12, 2009 03:26 PM
