Needing a frame for a 69 442
Old May 13, 2013 | 08:02 PM
raw442's Avatar
Exclamation Needing a frame for a 69 442
I need a frame for my 69 442. I also need it as close to mid Missouri as possible. I'm on a limited $$$ and don't want to spend half for fuel. As most already know it needs to be a 68-72 A body GM 2 door or convert. NO 4 dr of wagons. I really need some suspension on it; trailing arms upper and lower and all suspension springs to go with it. I also need one 28 spline axle. I have a disc brake set up and a axle housing with 4:10 gears already. Please any info is appreciated. I have several leads around me already, but something is holding up on each one.
Last edited by raw442; May 13, 2013 at 08:07 PM. Reason: I need this moved to parts wanted.
Old May 13, 2013 | 09:17 PM
orange442's Avatar
How far are you from Bartlesville, OK? I am almost finished parting a 71 Cutlass 2 door with a nice frame. I also have a complete 69 400 motor if you need one for your 442? I also have a 70 O type 12 bolt that should have an axle for you as well. What else are you looking for?
Old May 14, 2013 | 03:22 AM
rcktdoc's Avatar
I have a 69 frame clean some surface rust but very solid,I have trailing arms( Not boxed) and a rearend.Call me for specifics and price.Im in northern IL 224-234-3860
Old May 14, 2013 | 04:26 AM
507OLDS's Avatar
I'm a little far,but I have one that you could polish.It is that nice.I have suspension pieces to match it too.
Old May 14, 2013 | 05:23 PM
raw442's Avatar
My parts car finally came through. I got my frame. Thanks for all the responses everybody!
jcdynamic88
Sep 24, 2013 05:17 AM
dsa2207
Cars Wanted
Jan 28, 2013 05:06 PM
Coach6
Sep 18, 2012 03:43 PM
Chris Rothwell
Jun 9, 2012 07:04 AM
Cranbrook
Aug 27, 2008 04:27 AM
